IGuidance Embed - Sound Files Missing or Corrupted Error
  • IGuidance Embed - Sound Files Missing or Corrupted Error
    I'm wondering if anyone else has seen this issue.
    I have installed IGuidance and set it up as an embedded application in CF. When I launch it from within CF, however, I receive an IGuidance error message that says that "sound files are missing or corrupted, please reinstall." This keeps IG from loading. I have uninstalled and reinstalled IG with the same result. I do not get the message and IG loads fine when I load it directly (not from CF). Any ideas?
    My setup in external.xml is:
    <PATH>"C:\Program Files\iNav\iGuidance\iGuidance.exe"</PATH>
    <PARAMETERS></PARAMETERS>
    <WINDOWNAME>IGuidance</WINDOWNAME>
    <DISPLAYNAME>IGuidance</DISPLAYNAME>
    <PAUSEMUSIC>True</PAUSEMUSIC>
    <LINECONTROL>NONE</LINECONTROL>
    <MUTEONEXIT>False</MUTEONEXIT>
    <STARTFULLSCREEN>True</STARTFULLSCREEN>
    <ENABLEHEADER>False</ENABLEHEADER>
    Are you using 1.4? I believe 1.3 ran the app from the CF directory rather than the iG directory which is why you get that error. I thought that was fixed in 1.4 though. Hummm, actually, maybe you should just remove the quotes ("). I think that may fix it.
    PS: You may also want to try out SKINbedder or iGMod.
      yep... just lose the quotes... it is causing it to improperly set the working directory, therefore creating your error...
      david
        Removing the quotes did the trick. Thanks.
