#1 Request for 1.5
  • #1 Request for 1.5
    My biggest request that I hope can make it into 1.5 is for CF to be able to load things on start-up when it is the shell. Right now I have to goto Apps to launch Girder and Delorme Serial Emulator if I want to use my remote, Powermate, steering wheel controls, or GPS. I know I could setup a bat file as the shell or something, but that just seems messy to me and I've never gotten around to doing it.
    I would also like to be able to launch and embed iGuidance and GPSSecure on startup in the background, but that is secondary to just being able to launch Girder & the GPS serial emulator which are both "system-tray" apps.
    Please consider this a priority after you are done with the SDK David. TIA.
    PS: My second most-missed feature would be to continue the song where it left off rather than starting it from the begining. Both of these 2 features are critical for those of us not using hibernation.
    I plan to take care of both of those... Question about remembering the position... The latest versions of Centrafuse write any setting changes when they happen.. this way you can shut off the computer improperly by killing the power and Centrafuse will remember all your settings... The problem is with the current position I don't really want to do extra IO every single second... Do you use a shutdown controller to properly shutdown windows? I can easily add the code to remember postion when the app receives the shutdown command, but I'm not sure how many people there are that don't properly shutdown windows...
    david
      Awesome! Thanks David.
      Anyone just killing power to their PC rather than shutting it down is just asking for trouble. Saving the time on a proper shutdown is fine (you should do it as soon as you recieve the shutdown request because my music keeps playing while the PC is shuting down, but my radio is already off so I can't hear it).
      If you wanted to be just a tad safer than that, you could additionally save the time every minuite or 30 seconds or something, but I have no need for that personally.
        I think if you have to kill your PC instead of proper shutdown, you have bigger problems than just remembering the position.
        Just save the position upon proper shutdown. My 2c!
        2002 Honda CR-V
        Spent so far: $1105.90
        ...or even Listen to my music
          that's pc murder!
          [4Runna]
          next - wifi
            As stated in the request thread, Id also like a way to launch applications but not necessarily embed them as a windowed app
            2004 G35 Coupe project
              X.....M.......this is getting rediculous
                I would like to see XM support as well.
                  It will soon follow as a Plug-In once the plug-in SDK is released. Let him get 1.5 out first .
                    I'm wondering what those problems are. I have done hard shutdown on my carputer literally thousands of times without any problems.
                      no probs what so ever. its old wives tale.
                      Why? OS have to recover from normal problems in electricity input, otherwise we would all be using UPS with diesel or gasoline generators...
                        A way to minimize CF
                        (or)
                        " Show desktop " , which also minimizes CF
                        there are way to do it currently, but not a "button" on CF
                        maybe put it next to the "connect" but not into the " fullscreen " click area.
                        would also be nice to enable/disable this feature for those not wanting it in the tools/setup/xml etc ...
                        just a thought.
                          (or)
                          just a thought.
                          Download AltTabber... Great program! You can minimize it that way. Basically there is a box on your screen and it has a left and right side feature...You can set whichever side to minimize "everything" You can make the box invisible, but just remember where you place it....
                          2002 Mitsubishi Galant
                          Carputer Specs:
                          Via M10K
                          512mb Ram
                          60GB HDD
                          Souund Blaster Audigy2 NX
                          OPUS ITX PC Case
                            (or)
                            just a thought.
                            I might look into hiding it somewhere, but I don't want a visible minimize option... I know it's something technical type people want from the forums, but with Centrafuse running on hardware systems installed in peoples car and CF set to run as shell, minmize would go to a blank screen... CF is designed to be a replacement and I try to hide the fact that it runs on Windows... All non technical people that would minimize would just get confused... I might just make it a potential button action... I really just want to add plugins for everything anyone wants to do with the system... hopefully when it's all said and done there will be no reason to ever want to minimize...
                            david
                              You people are nuts. Windows is constantly writing to your HDD and cacheing data that needs to be written to the HDD. If you just pull power, all data in that cache is lost, plus if the HDD was currently writing it could leave you with bad-sectors to say the least. Trust me, it's not good for the HDD to just pull power and it can lead to curruption of any open files on the HDD (incuding [and mostlikely] the OS files).
