Anybody....
  • Anybody....
    Anyboy here using CF 1.4 with a Sound Blaster Audigy 2 NX? IF so are you able to control Rear / Sub? How did u get it to work?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    more of an audigy 2 problem...
    you have to set up your speakers in the speaker program to be 5.1, then you go to bass managmenet. you want to select bass redirection. set the filter to "high"
    i dont know if cf 1.4 controls that from the fe...
    [4Runna]
    next - wifi
      I already have dont that...
      Carputer Specs:
      Via M10K
      512mb Ram
      60GB HDD
      OPUS ITX PC Case
        this has been covered so many times....
        the only way Centrafuse will control those channels is to install an old driver that places rear/center in the playback section of the mixer...
        david
          David,
          WHere can I get the driver? I only have the drivers that came on the cd....
          Carputer Specs:
          Via M10K
          512mb Ram
          60GB HDD
          OPUS ITX PC Case
            I have no idea... never owned one of your soundcards... I just use the sound drivers that came with my M10000, which place rear/center in the playback section of the mixer... The newest M10000 drivers place it in the "Other" section which I do not currently support... You can either wait until I add support or attempt to find an older sound driver for you card on the internet that may or may not place the rear/center in the playback section...
            david
