CF Serial Key Input
  • CF Serial Key Input
    OK i registered beta and have serial
    But seems something is missing
    Cliff Notes:
    1. open CF
    2. Click Register
    3. Wierd Error pops up
    4. Continue anyway
    5. No place to enter serial
    "Geeks dont need girlfriends we can ping ourselves"
    Sony Vaio 2Ghz 40G HHD, Routis 2004 GPS, 7" VGA TS Lilliput, BackUp Camera running RoadRunner with Simplistique Skin.
    ??? What's all that "#UIR_" stuff? Something is wack on your system.
      I get similar.. but no luck .. I'm back on 1.2
      david said to clean it all out and re-install.. but no dice there either...
      Shawn
      Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
        What OS are you running on, Windows XP? Does your system have courier new in control panel fonts? This system isn't nlited is it?
        david
          Windows XP Pro SP2 - yes font is installed and no not nlited
            Is it the English version?
            david
              yes english version
                Latest .NET network
                PowerVoice v1 | NaviVoice Source
                GammaControl v2.4
                SKINbedder v3
                1995 Lexus SC300
                  mine always asks for an install disk too... also no nlite and up to date .net
                  Shawn
                    Legal copy??
                    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
                    GET PAID TO SURF THE INTERNET
                      Please note regarding to the picture that he has 2 instances of centrafuse install running!!
                      EPIA M10K, 512MB RAM, 60GB
                      [##########] 100% (since 1 March 2005)
                      snowboarding.be - bokky.com
                        Please try to uninstall ALL versions of Centrafuse and then manually delete the folders where they were installed, reboot, and install 1.4...
                        david
                          Bokky: thats just an illusion to get the error message and the serial entry on screen
                          Will try a second install this evening
                            ok i have uninstalled CF
                            deleted remaining folders
                            updated windows
                            made sure I had .NET 1.1 w/Hotfix
                            reinstalled CF
                            Still a no go
                            Can I be the only one to see this?
                            I am currently using Cobra3 aka CarPlayer and decided to base my new install on the activity of softwares forum. Hopefully its just me
                            May try and install on another computer this evening
                              updated windows
                              reinstalled CF
                              Still a no go
                              This problem has been reported by about 3 people out of thousands of registered users... I am working to find a resolution to the issue, but it's almost always related to a .NET framework problem and/or problems with the GAC... I have tried and have yet to reproduce it or actually see it happen on any machine. Most likely it will work fine on another machine and also on the current machine if windows was reinstalled...
                              david
