Radio Shark and Centrafuse
  • Radio Shark and Centrafuse
    I've been using Road Runner till now, and I just started messing around with Centrafuse, and with a little modification, centrafuse works really nicely - its faster and more fluid than RR on my P3 600 and much simpler to use.
    Has anyone tried to use radio shark with CF... I got it to integrate pretty easily with RR, but I can't figure how to do it in CF....
    <-- that's how I got it to work in RR. I was hoping to do something similar in CF... any suggestions would be really helpful...
    I basically need to (a) embed it into CF so it sits in the given space and does move around, and (b) put in preset +/- buttons that will push the left/right keyboard keys and send them to the radio shark cuz the UI on the radio shark is too small.
    Thanks!
    edit: I got it to sit inside CF with the following code:
    <APP2>
    <PATH>C:\Program Files\Griffin Technology\radioSHARK\radioshark.exe</PATH>
    <PARAMETERS></PARAMETERS>
    <WINDOWNAME>RadioShark</WINDOWNAME>
    <DISPLAYNAME>Radio</DISPLAYNAME>
    <PAUSEMUSIC>True</PAUSEMUSIC>
    <LINECONTROL>NONE</LINECONTROL>
    <MUTEONEXIT>False</MUTEONEXIT>
    <STARTFULLSCREEN>False</STARTFULLSCREEN>
    <ENABLEHEADER>False</ENABLEHEADER>
    </APP2>
    The problem, however, is that the area size is wrong and it stretches wierd. And I need to add preset buttons... being able to add mute (spacebar) would be nice too, since radio shark has a very peculiar closing behaviour which I suspect CF won't like.
    edit2:
    this is the best I can get it to embed in centrafuse
    http://www.cardomain.com/id/dapcwiz | http://www.dapcwiz.com
    Touch where the song title displys across the top and it will get bigger.
    Here is fixed code so it starts full screen too. Might help you but i dunno cause i haven't tried it.
    <APP2>
    <STARTFULLSCREEN>True</STARTFULLSCREEN>
    </APP2>
      yeah I've tried that as well, but the radio shark UI doesn't scale... so I actually need it to be smaller not bigger....
        hmmm maybe I can use skinbedder v2 to correct this problem, I will try it tonite....
