New Release Centrafuse 1.5
  • New Release Centrafuse 1.5
    Happy Halloween!!!
    Here is Centrafuse 1.5...
    Go to the website http://www.centrafuse.com and download the latest version. When you signup you can request a serial number on your "My Account" page, after you login.
    Make sure to read the release notes, it describes how to use some of the new functionality.
    http://www.centrafuse.com/downloads/releasenotes1.5.txt
    This new version allows you to have multiple playlists loaded at one time. It was written to remember all previous playlists whether HD, CD, or USB, current playing song/video, and position in song/video after a restart, but I had to take that out at the last minute because of some serialization issues reading the old playlists. The code is in place I just have to switch it to write to the Database instead of files and it will be back in 1.6...
    It still remembers your last playlist and now even your current position in the playing song/video...
    When you insert an external HD/USB device it pops up a dialog showing the progress of loading the music from the external device. I had this screen freeze on me once during testing today. Let me know if this happens and post your error.log file...
    Hope you enjoy!!!
    David
      sweet downloading
      My Install
      Software:
      CFiG v1
      iGuidance Plugin for CF
      CarShell
      Working shell for a CarPC
      StopWatch
      StopWatch plugin remade for centrafuse RC1
        Time to give CF another try
        Roy
        2005 Range Rover 4.4
          will starting from the same spot in a song be optional? I liked not having to randomly jump into the middle of a song when I started my car.
          My 2002 F250 Install
            Umm...I can't get it to run. It loads the title screen and just shuts down. I uninstalled the previous version before installing 1.5 if that makes a difference. Here's my error.log:
            8/1/2005 1:28:52 PM
            Unable to perform cddb query.
            at Freedb.FreedbHelper.Query(String querystring, QueryResult& queryResult, QueryResultCollection& queryResultsColl)
            at centrafuse.freedb.readCDDB(String query, Form pform, cfbase baseform)
            10/31/2005 8:45:19 PM
            skins/Brushed Metal/screens/media_off.png
            at System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement)
            at System.Drawing.Image.FromFile(String filename)
            at centrafuse.ImageSkins.readImages()
            Value cannot be null.
            Parameter name: image
            at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y)
            at System.Drawing.Graphics.DrawImageUnscaled(Image image, Rectangle rect)
            at centrafuse.cfbase.OnPaint(PaintEventArgs e)
            10/31/2005 8:46:03 PM
              here is my error log
              My Install
              Software:
              CFiG v1
              CarShell
              StopWatch
                Just to be clear, do we need to request a NEW serial number, or can/should we use the old one?
                2002 Honda CR-V
                Spent so far: $1105.90
                ...or even Listen to my music
                  got it to work, i deleted out the old directory after the uninstalled centrafuse and rebooted
                  My Install
                  Software:
                  CFiG v1
                  CarShell
                  StopWatch
                    I had the same problem this morning. Deleted all directories, then when I ran install again, it came up with unistall option. Selecte that, an then installed an worked fine.
                      everytime i go int the program it tells me i must go into setup... i then go on save, overwirte config file, then close, and then when i relaunch CF it does the same thing over and over....
                      Roy
                        does this mean anything?
                        Originally posted by error.log
                        10/31/2005 11:56:40 PM
                        Object reference not set to an instance of an object.
                        at centrafuse.main.runLaunchCommands(String section)
                        11/1/2005 12:15:02 AM
                        at centrafuse.setup.saveBtn()
                        11/1/2005 12:15:14 AM
                        11/1/2005 12:16:20 AM
                        11/1/2005 12:16:57 AM
                        11/1/2005 12:17:05 AM
                        Roy
                          looks great....got everything you would want.....except XM! Sorry David, i know you worked really hard on this, and it's coming along nicely. So congrats on that. But, hopefully someone will quickly get an XM plugin out, otherwise, its not as good as RoadRunner yet.
                            David, this is spectacular! I like what I see!
                            Can you create a new thread for v 1.5 Bugs, under bugs subforum? I already found something reasonably significant.
                            2002 Honda CR-V
                              Checking it out now, thanks!
                              www.mobile-effects.com
                              Free file hosting, picture gallery hosting for installs, PM me.
                              Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
