Good Skins Don't Work
  • Good Skins Don't Work
    well, the awesome brushed metal day and night skins DO NOT work with 1.5.
    This is a pretty big let down, after all the work EMDZEY did to provide 2 very awesome "usable" skins that look good inside cars that do not have bright blue interrior trim. Any quick fix ideas?
    I only ask because using the default skin inside my green and tan interior makes the car look like it was designed by Stevie Wonder Custom Interiors.
    p.s. if you try this out and get screwed, unable to change back to the default skin. simply remove the new skin directories from the skin directory under centrafuse.
    check out the skin files for the changes? then you can fix the problem...
    Roy
    2005 Range Rover 4.4
