Destinator
  • Destinator
    How do I go about getting a new map for Destinator?
    The map it has looks like its in Germany right now...
    It's just for testing purposes... I will be reselling Centrafuse with Destinator once it's completed....
    david
      if you have maps already, then u can put them in the destinator map and switch map in CF 1.5
      David how can i temp. remove the destinator plug-in?
      I would like to use mapmonkey, since it has more features at the moment.
      www.superchargedmiata.net - all about roadster lifestyle
        What are you missing in the integrated destinator ?
        - Superbowl
        i never drink water cos fish ***** in it. (w.c. fields)
          - Superbowl
          for instance the speedcams, and the option to change the language.
            you can remove the desintator plugin by clicking "plugins" in tools, highlight GPS, and click "-"... It does not permanently delete the plugin, but moves it to inactive plugins, which you can add back later with "+"...
            david
              So when you package Destinator into Centrafuse - will it mute the music playing when it has an audio direction to give? That to me is the holy grail for frontend/navigation integration.
              My install log
              My "selling entire system" thread
                yes it will
                My 2002 F250 Install
                  david
                  Hi David..
                  This don't work for me..
                  Breake down:
                  I remove the GPS pluggin. Works fine.
                  Adds MapMonkey. Work fine.
                  But next time I restart CF it automatictly reinstalls the GPS plugin.
                  Any ideas why? Is it possible too completely remove the plugin? I've tried to remove the Destinator folders in plugins and pluginsinactive. Still the same. Reinstalls.
                  King
                    I found a way aroud it. I deleted the destinator.dll. and made a blank txt file and renamed it destinator.dll
                    Guess CF requires that .dll file..
                      Originally posted by kingchaos
                      Hi David..
                      Breake down:
                      King
                      It was an oversight in my installer... you have to mark things as removable or the next time you run the application it will automatically add them back...
                      this will not be a problem in 1.6...
                      I apologize for the invonvenience...
                      david
                        Thx 4 a quick A
                        Thanks for a quick answer..
                        King
                          Speedcams? Weird. We don't have those here in the USA to my knowledge, just traffic light cams...
                          Carputer Progress:
                          Re-do fabrication of screen [DONE]
                          Add mini-USB and micro-USB power from M2-ATX [DONE]
                          Teardown PC [100%]
                          Add HDMI > VGA converter [0%]
