How does CF 'voice commands' work?
  • How does CF 'voice commands' work?
    Can someone (David?) please care to explain in detail how the VOICE feature of CF is meant to work?
    Do I make the voice icon yellow before talking? Or is it the other way around?
    Regardless, I cannot get it to work, and I do have SAPI and all that jazz installed, with my mic activated.
    Also, wouldn't the loud music in car interfere with voice commands?
    Thanks!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    It doesn't work for me too, althought "speech" is ON in CF settings.
    It worked with the previous version. I just uninstall CF 1.4 and install 1.5 and set settings but doesn't work.
    New prototype : 2DIN AUDI OEM-LIKE CARPC based on SYMPHONY II
    Motorized InDash Screen, Core 2 Duo 2.2Ghz, SSD
    Home Made In-Dash 7" Lilliput V1
    Home Made In-Dash 7" Lilliput V2 = LM-Lilliput Prototype
    First project in Peugeot 306
      I can't get it to work either...the right buttom button has to be yellow, other wise the mic is mute.
      Renault Megane...the OEM look
        is SAPI installed?
        david
          Yes, SAPI is installed!
          David, just a few lines to explain how it operates? (i.e., what button to push, when, etc...?)
          2002 Honda CR-V
            once SAPI is installed and voice is enabled in setup, it should work...
            could be a bug... I will look into it...
            david
              Ok David, for the last time (!!!!) hahaha PLEASE TELL US HOW IT SHOULD WORK!
              Do I press button so it turns yellow, and talk? Or?!
              2002 Honda CR-V
                when you press that button and it is highlighted, voice is disabled... it works like mute... when highlighted it's disabled or not listening for commands...
                david
                  It works on mine. You must have the voice "non yellow" and say "computer" then the command I.E. "Computer load main menu" or "Computer load video" etc
                    Wish I could get it to work.
                    2002 Honda CR-V
                      make sure after you install SAPI you go to control panel and setup and train the profile or it will not work...
                      also once CF is loaded make sure, with windows mixer, that mic is selected as the recording source...
                      david
                        While we are on the subject of Voice commands,
                        I remember when 1.4 first came out it was discussed about the problem of actually being able to hear the output of the microphone through your speakers and how this was not that desirable. It seems to be still the case in 1.5.
                        David, can CF automatically mute the MIC playback through the speakers?
                          if you mute it in the windows mixer, CF should not unmute it and it shouldn't be a problem...
                          david
                            SAPI unmute the MIC. I made a program once called AutoMute.
                            PowerVoice v1 | NaviVoice Source
                            GammaControl v2.4
                            SKINbedder v3
                            1995 Lexus SC300
                              really? It doesn't on my system... I can code in to mute it... SAPI has never unmuted my mic... maybe when it is installed, but never loading CF.... or using SAPI from CF...
                              david
