OBD-2 external app! for CF available!
This topic is closed.
  • OBD-2 external app! for CF available!
    http://www.carobd.com/download.html
    http://www.carobd.com/files/carmmobd.zip
    Appilcation name: CarMM-OBD (or anything you like)
    Application path: c:\program files\CarMM\CarmmObd.exe
    Application parameters: <posx> <posy> <window-width>
    example: 0 0 800 (for fullscreen on a 800x600 screen)
    example: 140 92 560 (for a screen that fits in the frame in 800x600 non fullscreen)
    Window name: CarMM-OBD Module
    Try to tap at the controls...
    www.carobd.com
      1.6 will have integrated OBDII...
      david
        With the same features?
        www.carobd.com
          and Duke Nukem Forever will be the best FPS on the planet. Its a race between them to see which will be released first
            duke nukem isnt a free program developed by 1 person, give him a break *******
            PC Components:
            My work log
              No idea what you talking about....
              NEW UPDATE
              You can now set Screen height & width and change the background images.(Gauges not fit to any resizing)
              CarMM Stand alone OBDII Module
              To use as external application.
              Parameters: <posx> <posy> <window-width> <window-Height>
              example : CarmmObd 10 10 800 600
              Change background bitmaps by setting the following parameters in c:\windows\win.ini
              [CarPC]
              www.carobd.com
                centrafuse wont be free either... this is a free beta test, remember?
                  Do you have a demo version of your OBDII software? I would like to verify compatibility with my OBDII hardware. I have the CarPal Bluetooth OBDII unit.
                  Also, can you shift your units to english units (i.e. MPH instead of KPH, etc.).
                    Do you have a trial version ? A list of supported hardware ?
                    my Megane II install
                      1.6 doesn't yet have gauges, but yes it will support all features in the commercial version....
                      david
