CF 1.6 shows protected system files !!
  • CF 1.6 shows protected system files !!
    CF 1.6 shows protected system files like system voluem information and media player it is also show the hiddin jpg's and ini's used as a cover art
    this should be fixed\thanks
    We Exist because there is no patch for human Stupidity !!
    We need you ALL Here !!
    Where? In the file browser where you select music paths?
    david
      That's a Windows Folder Options setting...
      I don't use CF (although I might start!)m but I don't believe an application can override that.
        david
        yes
        Peugeot 206 1.4 HDi
        Intel Mini-ITX Mainboard
        Celeron 1.2ghz
        256mb DDR-2 533
        80gig 3.5" SATA HDD
        Sb Live 5.1 w/ KXProject Drivers
        M2-ATX
        8" Lilliput TS LCD
        100% installed and working :D
          david
          David for me it appears every where when i play mp3 files it shows the hiddin jpg file in the list when i add music paths or any thing that has a list with browsing option !!
          by the way i have the opption hide protected system files (Recommended) enabled
          Bashar
            Bashar
            under media manger their is a bug when browsing by music paths which makes it show the images, hidden or not... this will be fixed...
            david
              david
              this is one of them
              it is in media player also
              it is in settings when i set the music and video and photo paths
              i will tell you if i fint it anywhere else
              by the way did you tried the MAP ??
                this is one of them
                You see files when you set the music/video/picture paths? You should only see folders...
                That map should work fine...
                david
                  david
                  no i dont see files here only the folder "System Voluem Information"
                  good news about the map so it will work with D6 thanks for your help
