Password Protect Settings Button (David) ??
  • Password Protect Settings Button (David) ??
    David please can you add a password to protect the settings button it will be a good idea to not let other pepole to mess with your settings (my friends, when i leave the car in the carage)
    and it should be something diffrent to lock screen password
    thanks
    We Exist because there is no patch for human Stupidity !!
    We need you ALL Here !!
    thanks
    Not a bad idea... You think it should be a different password than the lock screen? I can potentially see adding the password dialog if a password has been set, but it would unlock with the same password as the lockscreen.
    david
      david
      it will be ok i think, if i set a password for lock screen then password dialog will appear when i press on Settings Button this works for me thanks man.
      regards
        david
        Please david, don't put a password need for enter setting as default setting...
        let it configurable.
        Idon't want to enter a password each time i enter setup
        New prototype : 2DIN AUDI OEM-LIKE CARPC based on SYMPHONY II
        Motorized InDash Screen, Core 2 Duo 2.2Ghz, SSD
        Home Made In-Dash 7" Lilliput V1
        Home Made In-Dash 7" Lilliput V2 = LM-Lilliput Prototype
        First project in Peugeot 306
          it is not a need if you set a password for lock screen so it will ask you for same password when press on settigns button, else it will work as normal.
            OK
