centrafuse: wich audioplayer engine is used
  • centrafuse: wich audioplayer engine is used
    hello
    does anyone know wich media engine is used in centrafuse, or has he made one his own..?
    Sorry for the english
    CarPC Specs.
    Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
    Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
    DirectX....
    david
      the man himself.
      it is really great software you have made, but i would like to try to make my own, and i dont like winamp because of the sdk's limitations i think..!
      great you being so helpful..!
      thanks for the quick answer
      CarPC Specs.
        just one question though.. are you using a directx sdk, og are you just using the library..?
        CarPC Specs.
          It all depends on what language you are writing in... It's all going to be C++, but you can call from VB, and interop in .NET... Just do some research into audio/video playback using DirectX... I don't recommend using managed DirectX, which is what I use to use... It was a terrible attempt by Microsoft to wrap up and simplify DirectX use in .NET...
          david
