1.7 Progress report
This topic is closed.
  • 1.7 Progress report
    Here is the progress of 1.7. First is a list of features already fixed/added.
    New Features
    Removed two buttons from bottom global navigation and increased the size of the play controls
    Added full screen video overlay, similiar to DVD overlay
    Double clicking visualizations makes them go full screen
    Added support for UltraPlayer visualizations
    Clicking any button will hide the system drop down menu, if it is visible
    Adjustable aspect ratios added for videos, now defaults to correct aspect ratio
    Added the ability to control application with keyboard with up/down/left/right/tab/backspace
    Matched hotkeys to standard windows remote commands
    TV plugin now has support for most standard TV tuners
    Decreased main drop down menu timeout
    Settings has been re-designed to include all setup options in one list view
    Added the ability to use custom resolutions through settings interface
    Added CF_changeSkin function to the SDK
    Added "..." to truncated songs in the main title
    Enhanced initial setup process
    Album art is retrieved when importing a CD
    When the password is wrong lockscreen displays "invalid password" dialog
    Volume change speed increases as you hold down the buttons
    Logarithmic volume is now optional
    Recording levels and wave output are always linear
    Added search by filename to media manager search dialog
    Added additional hotkeys
    Added feature to record videos with CAM
    Pictures and videos from CAM automatically show up in the media manager
    GPS is fully integrated into application, no longer a plugin (it can still be disabled and not used)
    Added icon support for external applications (place "<external application name>.png" in the icons folder)
    Language and Skin settings removed from all plugins, they are controlled from General settings in setup now
    GPS allows you to navigate at any point during the address navigation process, such as navigating to a city or street
    GPS now has an OSK to allow you to narrow your list of cities, streets, and house numbers
    General settings now has location for Day and Night skin
    Button added to toggle day and night skin
    New day skin has been created
    Added a hotkey for go to previous section
    Media player list view is now single click
    Random button is now a toggle like mute
    Added phone battery and signal icons to the global information display
    The taskbar is hidden while the application is run
    Holding favorites in media player for 3 seconds loads your favorites playlist
    Option to hide taskbar on startup
    When you click weather and no location is set, a dialog is displayed telling you to go to settings
    When password set settings is also protected
    Added unlimited previous history
    Web browser new window links now display within the same browser window instead of not showing up at all
    When importing a CD you can click away and continue to use the application, you will be alerted when it's finished
    Bugs Fixed:
    TV plugin properly resizes when resolution or skin changes
    DVD properly resizes when resolution or skin changes
    External applications keep focus when dialogs are launched
    Full screen visualization should now close on slower computers
    You can now remove plugins from within settings
    Settings is now an available button action
    Drop down menu does not break when you modify the button layout
    Voice settings enable/disable option displays proper text
    External applications setting full screen on/off properly works
    All line devices are defaulted to None
    Settings properly hides when using hotkeys to navigate to other sections
    Changed settings are remembered as you change pages before you save
    Volume information dialog properly resizes when resolution is changed
    Changing skins properly reloads skin icons
    Pause button properly updates when playing videos
    Directory icon is displayed next to playlists in media manager
    Album art first checks for folder.jpg, then checks the file for embedded album art
    Settings section properly resizes when resolution is changed
    When cross fade time is set to 0, cross fading is disabled
    Fixed file filter, extra files such as pictures will not show up when adding music
    Files with a ' character in the filename will properly import
    Web browser paging buttons have been fixed
    Improved tag reading, track numbers and unicode characters fixed
    Mouse cursor is hidden on resume from hiberation, if enabled
    Voice commands properly save when set in settings
    Calculating route dialog added to all route calculations in GPS
    Plugin display name is now properly read from language file
    All pictures now load when selecting a picture and hitting play now
    Pause icon properly displays when loading a video
    Album art now updates when not in the media screen and the current album changes
    Eject properly works when pictures are loaded
    Phone does not display setup wizard on load when phone is not configured
    Phone properly reads contacts
    Album art properly resizes when resolution is changed
    Hotkey events are disabled while changing hotkeys
    Hidden directories and files are no longer shown
    Playlist properly loads after viewing picture paths
    Playlists and favorites properly load
    Queue reloads if emptied and the media manager is cancelled
    Fixed header display problem that showed radio whie in media mode
    GPS does not unmute audio when music paused
    When hide cursor enabled it hides on startup
    During the initial setup wizard, rebuild library automatically starts
    Pressing pause/play no longer breaks previous track
    Random should not repeat any song until the entire playlist has been played
    Volume is changed back before it starts playing when exiting DVD player
    DVD menu button works
    DVD skip chapter works
    When hide cursor is enabled, the cursor is hidden when watching DVD's
    Generic art properly displays when playing a CD
