Centrafuse XLE RC1 Release Notes
This topic is closed.
  • Centrafuse XLE RC1 Release Notes
    Here are the release notes for Centrafuse XLE RC1. Please read through at least the features so you know about all the new additions to Centrafuse.
    Release Notes
    Version: RC1
    Date: 07-12-2006
    New Features
    1. Removed two buttons from bottom global navigation and increased the size of the play controls
    2. Added full screen video overlay, similiar to DVD overlay
    3. Double clicking visualizations makes them go full screen
    4. Added support for UltraPlayer visualizations
    6. Clicking any button will hide the system drop down menu, if it is visible
    7. Adjustable aspect ratios added for videos, now defaults to correct aspect ratio
    8. Added the ability to control application with keyboard with up/down/left/right/tab/backspace
    9. Matched hotkeys to standard windows remote commands
    10. TV plugin now has support for most standard TV tuners
    11. Decreased main drop down menu timeout
    12. Settings has been re-designed to include all setup options in one list view
    13. Added the ability to use custom resolutions through settings interface
    14. Added CF_changeSkin function to the SDK
    15. Added "..." to truncated songs in the main title
    16. Enhanced initial setup process
    17. Album art is retrieved when importing a CD
    18. When the password is wrong lockscreen displays "invalid password" dialog
    19. Volume change speed increases as you hold down the buttons
    20. Logarithmic volume is now optional
    21. Recording levels and wave output are always linear
    22. Added search by filename to media manager search dialog
    23. Added additional hotkeys
    24. Added feature to record videos with CAM
    25. Pictures and videos from CAM automatically show up in the media manager
    26. GPS is fully integrated into application, no longer a plugin (it can still be disabled and not used)
    27. Added icon support for external applications (place "<external application name>.png" in the icons folder)
    28. Language and Skin settings removed from all plugins, they are controlled from General settings in setup now
    29. GPS allows you to navigate at any point during the address navigation process, such as navigating to a city or street
    30. GPS now has an OSK to allow you to narrow your list of cities, streets, and house numbers
    31. General settings now has location for Day and Night skin
    32. Button added to toggle day and night skin, hold down dim for 4 seconds
    33. New day skin has been created
    34. Added a hotkey for go to previous section
    35. Media player list view is now single click
    36. Random button is now a toggle like mute
    37. Added phone battery, signal, and headset icons to the global information display
    38. Holding favorites in media player for 3 seconds loads your favorites playlist
    39. Option to hide the taskbar while the application is run
    40. When you click weather and no location is set, a dialog is displayed telling you to go to settings
    41. When password set, settings is also protected
    42. Added unlimited previous history
    43. Web browser new window links now display within the same browser window instead of not showing up at all
    44. When importing a CD you can click away and continue to use the application, you will be alerted when it's finished
    45. When selecting a COM port the actual available ports are shown instead of a static list of ports
    46. Volume progress displays min/max when peaks are reached
    47. Added enhanced graphics option for fade effects and smooth transitions
    48. Added option to specify what time of day to switch to day and night skin
    Bugs Fixed:
    1. TV plugin properly resizes when resolution or skin changes
    2. DVD properly resizes when resolution or skin changes
    3. External applications keep focus when dialogs are launched
    4. Full screen visualization should now close on slower computers
    5. You can now remove plugins from within settings
    6. Settings is now an available button action
    7. Drop down menu does not break when you modify the button layout
    8. Voice settings enable/disable option displays proper text
    9. External applications setting full screen on/off properly works
    10. All line devices are defaulted to None
    11. Settings properly hides when using hotkeys to navigate to other sections
    12. Changed settings are remembered as you change pages before you save
    13. Volume information dialog properly resizes when resolution is changed
    14. Changing skins properly reloads skin icons
    15. Pause button properly updates when playing videos
    16. Directory icon is displayed next to playlists in media manager
    17. Album art first checks for folder.jpg, then checks the file for embedded album art
    18. Settings section properly resizes when resolution is changed
    19. When cross fade time is set to 0, cross fading is disabled
    20. Fixed file filter, extra files such as pictures will not show up when adding music
    21. Files with a ' character in the filename will properly import and play
    22. Web browser paging buttons have been fixed
    23. Improved tag reading, track numbers and unicode characters fixed
    24. Mouse cursor is hidden on resume from hiberation, if enabled
    25. Voice commands properly save when set in settings
    26. Calculating route dialog added to all route calculations in GPS
    27. Plugin display name is now properly read from language file
    28. All pictures now load when selecting a picture and hitting play now
    29. Pause icon properly displays when loading a video
    30. Album art now updates when not in the media screen and the current album changes
    31. Eject properly works when pictures are loaded
    32. Phone does not display setup wizard on load when phone is not configured
    33. Phone properly reads contacts
    34. Album art properly resizes when resolution is changed
    35. Hotkey events are disabled while changing hotkeys
    36. Hidden directories and files are no longer shown
    37. Playlist properly loads after viewing picture paths
    38. Playlists and favorites properly load
    39. Queue reloads if emptied and the media manager is cancelled
    40. Fixed header display problem that showed radio while in media mode
    41. GPS voice prompts do not unmute audio when music paused
    42. When hide cursor enabled it hides on startup
    43. During the initial setup wizard, rebuild library automatically starts
    44. Pressing pause/play no longer breaks previous track
    45. Random should not repeat any song until the entire playlist has been played
    46. Volume is changed back before it starts playing when exiting DVD player
    47. DVD menu button works
    48. DVD skip chapter works
    49. When hide cursor is enabled, the cursor is hidden when watching DVD's
    50. Generic art properly displays when playing a CD
    51. Clicking volume multiple times while in TV, DVD, and Video does not hide overlay
    52. When radio is paused media properly plays when you switch sections
    53. Only one instance of Centafuse can now be run
    54. Phone numbers properly save in internet settings
    55. Internet status dialog properly displays the status and connects
    56. Dual monitor settings properly resize and save
    57. XMPCR works on resume from hibernation
