Phone Control list of Bugs i Found !!
  • Phone Control list of Bugs i Found !!
    i was testing my new SE K800i mobile i have everything functioning but i have some issues:
    1- when i recive a message a dialog appears telling me about new message but it is not showing the number or caller name (message sender)
    2- recived calls missed calls dailed numbers are showing only the date without time.
    3-when i open inbox some time i get the same name for all messages , other time i get numbers even if i have these numbers saved in phonebook or sim and some times it showing correctly.
    4- headset is not shwing at all even when i connect my head set to the phone.
    5- signal is not showing correctly i have 2 or 3 lines on CF but the signal is full on Phone.
    6- refresh for signal , battry icons is veryslow.
    7- i am suggesting redesign inbox dialog as folows this will give the ability to view long messages and it will be easier to view another message by clicking on the messages list
    8- when i am calling someone then i press the end button on the head set the calling dialog will not disapear and i have to press end call button on it to close and start music again.
    peace
    We Exist because there is no patch for human Stupidity !!
    We need you ALL Here !!
    I will answer some of your questions.
    This is a configuration thing. Open PhoneCtlConfig.exe from the PhoneControl.NET path and go to the Communication [SonyEriccson New] section where the phonebooks are defined. Search for the RC phonebook then add showTime to the attributes list and set it to True.
    This applies to all non-static phonebooks.
    I have been told that this happens on the remote interface but I couldn't reproduce and find the nature of it. I'm still on it.
    The headset symbol is shown only in case the PC is the headset (or the headset would connect to the PC - which doesn't apply here). There's no way the PC can figure that you've connected two other devices.
    There's no relation between the bars in PhoCo / CF and the phone because it's different on each phone. The golden rule says: Many bars = good signal, Not as many = worse signal.
    In fact it's every 20 seconds. On SE phones you could add the UseCMER option in the Communication section as described under (2) and set this to True then add attribute mode and set it to "3,0,0,1". This will cause the phone to report such things as signal quality as they change.
    For other phones than the SE this feature may not work!!
    peace
    Yap, if you do this, you'll have to wait 20 seconds until the status gets refreshed. To get an immediate status refresh use the tweak above (6).
    Skinning to go... VisualDesigner2!
      how can i make the pc as a headset ? how can i hear and talk through PC speakers and mic ??
        http://phoco.net -> forum
          thanks man SE K800i works perfect everything works for me now
          man can you suggest me the cheapest SE mobile that has full functionality ??
            I use the SE T637 and the SE t68i, both work great and can be found on ebay... the T637 works a little better, the t68i is pretty old...
            david
              david
              thanks man you are the one
