Playing full screen video only to rear screen
  • Playing full screen video only to rear screen
    Hi David, My name is Yossi and i'm from Israel. I'm testing your software for the last 3 weeks and I'm doing it because you are the first one that supporting Destinator SDK 5.
    We are working here as team for translate this software to Hebrew and i think it will be ready 3 weeks from now. Until that the GPSKeyboard is ready for using it at Israel because all data maps are written in Hebrew so the GPS keyboard should be the same.
    I have two problems that I didn't see any questions from others:
    I have an onboard video card with VGA out for the front touch screen and SVHS out for the rear screen. I'm runnig the system on Multiple Monitors as clone mode with full screen video to the rear screen only. When I start a movie from regular player I can see it full screen on the rear display and I can working with other application in the same time on the main screen but when I'm playing video from CF/media I have to click full screen for it because if I didn't click on the small display I'm seeing the same format as small CF display but full screen.
    Bottom line when I'm playing it from CF and didn't change it to full screen, the video on rear screen squeezed by the CF format and the only way to fix it is to double click on small media video for full screen and now I can't change it to other app in the same time.
    The second question is some time my OBD-II (ELM323) disconnected and I need to click for new connection. Did you have any idea what should be the root case?
    Hebrew GPSKeyboard photo:
    http://www.jeeptrip.com/page.aspx?di...=4&item=740082
    This happens sometimes with the OBDII, we are looking into it...
    As for the dual screen issue... There is a lot more dual screen support in the upcoming release... The dual screen was designed around the secondary screen not being a clone, but just a nice background...
    You can now send Navigation, OBDII, Web, External Applications, Video, DVD, Visuals, TV, CAM...
    Just about everything to the rear screen and still have full control on the main monitor...
    I will make a note to look into how to get around the fullscreen issue you described for people who like to clone...
    david
      So, do you have other option to make this happened with the same VGA? My sagest is to leave the resolution as original and then everything will work properly.
      Can I change the resolution to original size?
      Other issue, I have media files with Hebrew fonts and CF is supporting because OS supporting that, but just in small place I'm seeing gibberish. (Only music files and in the screen server mode)
      What is the different between all places in CF to this specific place?
      Please take a look on photos and let me know what I can do to solve this issue.
      Yossi.
        David, can you help me with the gibberish or this issue from OS and you can't tell me what is the root case.
        Yossi.
