OBDII device
  • OBDII device
    I borrowed 2 OBDII cables from a garage, but unfortunatly it didn't work. They use it with VAG-com, so i think that's the problem.
    I want to buy a ELM based cable now, so it will work with Centrafuse, but i can't find the right one to choose; there are sooo many....
    Can someone help me out please? I drive a VW Caddy (same as VW Polo 6n) from 1999. Thanx!
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
    you can always get one from http://www.scantool.net, the ElmScan5 will work with just about anycar...
    david
      do the tactrix cables work?
      http://www.tactrix.com/
        not sure... anything based on an ELM chip will most likely work...
        the EML 327 chip is the better...
        david
          david
          Thanx David, i think this is just what i was looking for!
          AsRock AM2 dual VGA
          AMD Sempron 3000+
          512MB DDR
          3,5" 80GB harddrive
          Liliput 7"
          TFT 15"
          M2-ATX
          0% [OOOOOOOO-] 100%
          My install
            yes the Tactrix Cables work, and so does EvoScan for Mitsubishis and works with generic OBDII tools. http://www.limitless.co.nz/Evoscan/
