Request: show gps speed in all screens and in vis
  • Request: show gps speed in all screens and in vis
    I've tested Centrafuse for a while now and I love it
    Apart from the obvious things like beeing warned of speed cams (that I see that is a work in progress), I'm wondering if it's possible to show the GPS speed in all the screens (besides the clock or something). Also would be great to show speed in the visualization screen. Also would be great to show the number of satellites it's currently tracking in parentheses behind the speed so you would get an indication on how reliable the speed data is.
    Another thing. Mapmonkey had a cool feature that enabled you to run a task when reaching a certain gps point from a certain direction. IE, you could open the garage door when getting home and starting a filesync with the local lan. It would be a great way of automating task when getting to a certain location.
    Best regards
    T-Bear
    Best regards
    T-Bear
    good ideas for sure... primarily focused on getting the updater and the bugs worked out to get a stable first version finished... Then I can focus on adding all the cool features that have been requested....
    david
      I understand
      I don't know if this is a reported bug or not, but this morning I tried setting music fade time to 1, it resulted in no fading at all. Setting it to 1.5 resulted in 2secs, and I think that is too long. Could this be fixed?`
      Best regards
      t_bear
