Griffin Airclick ?
  • Griffin Airclick ?
    Has anyone here successfully figured out a way to make griffin airclick work with Centrafuse? I heard one way to pull it off was to use Girder I believe, but I am a bit lost with using that program
    Any help would be much appreciated! Thanks in advance!
    if you can make it send hotkeys then the rest is easy...
    or a simple plugin that can access the device with a DLL that calls system commands...
    both would be pretty easy to make...
    david
      Hey david good to see you're on these forums too! Unfortunately, I'm not too fluent with what you jus said.... I was hoping someone else out there did it already and is generous enough to share it!
