kX driver solution with YouP-Pax (Audigy 2ZS)
  • kX driver solution with YouP-Pax (Audigy 2ZS)
    I had installed the kX project drivers, but they dont work with CF. This thread has another solution with line-in from onboard sound, but i dont have onboard sound So i searched for an alternative solution for using my audigy 2 zs with CF.
    U only need the YouP-Pax drivers and the Audigy4.iso to patch your audigy 2zs to audigy 4. The advantages of audigy 4 is the better software, much settings and good tools.
    On this page u have the instruction. Simply follow there instructions. Nearly all links there are down, here are some alternative links:
    The Audigy4 image, the patch and the newest YouP-Pax drivers you can find here. The spkcal (Speaker Calibrator) is uploaded here.
    Im happy with his solution, the sound is very good and every speaker can be controlled.
    are you abte to create DSPs and xover networks, channel delay and so on? like kx does? ah btw David solved KX issues on CF RC5
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
