speed plugin
  • speed plugin
    hi
    I would like to see on centrafuse's GPS how fast I'm going at all times, and not position or satellite number. Is there any plugin to do that? My centrafuse version is 1.14
    best regards, Filipe Abrantes
    if you get iguidance navagation software that enbeds into cf with the plugin u download that tells u right on the botom all the time your speed.
      You can change the options in CF to not scroll through the information and just stick on speed, that's what mine does right now.
      Carputer Progress:
      Re-do fabrication of screen [DONE]
      Add mini-USB and micro-USB power from M2-ATX [DONE]
      Teardown PC [100%]
      Add HDMI > VGA converter [0%]
        I've seen the speed reading overlayed on the map in Destinator 3 before.
        Is it possible to add a line to a .ini or .xml file in CF to show this in Desti 6? If so, where and what needs adding?
        Cheers,
        Ken
          Cheers,
          Ken
          would love to have this too, if possible!
