Standby/Hibernate/Resume events
  • Standby/Hibernate/Resume events
    Any chance of having them fired by CF rather than using the servicebase class ?
    /M
    Maybe I was a bit unclear ?
    As far as I know there isn't any way to tell when CF is shuting down and when CF have resumed (fully) from a suspend/hibernate state.
    Yes, you could use the servicebase class to monitor Windows, but since CF allready handles suspend/resume it would be nice to have an CF event like "CF_Suspend" and "CF_Resumed".
    Could you add this to the SDK, David, please ?
    /M
      /M
      It's already there... Check out CF_Event_powerModeChanged event....
      david
        Look at that !
        And yet I searched... so how do I tell if it's suspending or resuming ?
        /Magnus
          Look at that !
          /Magnus
          A parameter is passed into the function... It will let you know if the machine is suspended or resuming...
          david
            You make me feel really stupid
            And those parameters are ?
            I downloaded the lastes SDK-help file a couple of days ago, and in that file I can't find those parameters.
            Clicking on "PowerModeChangedEventArgs" just ends up in a 404.
            "The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings."
            Many thanks,
            /M
              Many thanks,
              /M
              That Args class is a Microsoft one that I pass...
              http://msdn2.microsoft.com/en-us/lib...eventargs.aspx
              That link was suppose to link to the online msdn... There is a mode property on the class that has what you need...
              http://msdn2.microsoft.com/en-us/lib...owermodes.aspx
              Resume
              StatusChange
              Suspend
              david
                Thanks a million, if you'd be here I'd give you a kiss
                /M
                  Sorry to bother you again, but since I'm quite new to C# I don't know if there's a problem with CF or it's just the simple fact that I'm a bit thick
                  When I try to assign the "powermode changed" event to a new event handler I get an error:
                  this.CF_Event_powerModeChanged += new EventHandler(iBUS_CF_Event_powerModeChanged);
                  "Cannot implicitly convert type 'System.EventHandler' to 'Microsoft.Win32.PowerModeChangedEventHandler'"
                  Many thanks,
                  /M
                    Many thanks,
                    /M
                    Check out http://www.centrafuse.com/api for details on all the types... Power event mode should be declared as:
                    this.CF_Event_powerModeChanged += new Microsoft.Win32.PowerModeChangedEventHandler(power ModeChanged);
                    And the method would be like following:
                    private void powerModeChanged(object sender, Microsoft.Win32.PowerModeChangedEventArgs e){
                    Then you will want to check parameters on the Args e to determine whether it is a Suspend or Resume event...
                    david
