Frodo: 1.0.9 Hacking.
  • Frodo: 1.0.9 Hacking.
    Just figured that would get a lot of attention.
    Looking at the options, looks like we can pretty much hack this software to do everything we want!
    Use this thread for tips/tricks, or any other cool things you have found.
    I am interested if anyone has any good ideas on how to use the "Run Command on Resume" function. (like restarting USB devices or something)
    1. Here is a good tip for renaming all your .jpgs folder.jpg (for Album Art)::: (contributed by Big Zack)
    Run this at a command prompt in the root of your music folder.
    Code:
    Code:
    for /r %a in (*.jpg) do ren "%a" album.jpg
    2. Found the secret program: Frodo built sync software in (like sync folders over the network)
    www.i-hacked.com Hardware hacking articles
    ...ehm..presuming that there's only one(1) .JPG in the target(ed) directory AND it's cover art..
    If you have multiple .JPGs (cover, inside, back, etc...) then be careful with that axe Eugene!
    •Micke
      what does it do if there are several jpgs in the same folder?
      Signature: [==||========] 20% complete
        all i know is that i changed all my pic that were named from "cover" to "front" solely because i have he fronts and the backs of almost all the albums
        which brings be to question, can frodoplayer so multi pic in the visuals?? ex: the front and the back..
        Download Skin For FrodoPlayer 1.0.9
          don't quote me but if your cover stuff is called cover.jpg then just do this:
          Code:
          for /r %a in (cover.jpg) do ren "%a" album.jpg
          CarPC install is starting to come along again...
            That will work. You can put what ever the name you currently use for covers, like Grayscale showed.
            An easier way would be to change it in fordoplayer, if all your album art is the same name. If all your covers are named cover.jpg instead of album.jpg just go to menu -> setting 2 -> misc3 and change the default name for the album art to what ever you have them named.
            Installed
            Asus A7N8X-VM - AMD Mobile Athlon 2400
            512 Ram - 60GB HD - Opus 150w
            Lilliput 7" - Rikaline 6010
            [00000000000001100010-] 98% Completed
            Check Out My Install!!!
              Back on topic.. Anyone have any tips for the Run Command on Resume" function. (like restarting USB devices or something)
                There were some scripts somewhere in general hardware.
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
