Searching via Onscreen Keyboard.
  • Searching via Onscreen Keyboard.
    I don't know if this is related to my setup (not beefy enough machine), the skin I'm using, or what..
    When I try to do a search via the onscreen keyboard I select what I want to search for (either artist, album, or title) and then I hit the first letter I want.
    ALMOST (not always) every time I do this it will double the first letter and not catch the second letter.
    So let's say I'm searching for Avril... I will hit the "A" and it will show up "A" then about a full second later it will put another "A" on there. Then I hit the backspace key and it will erase BOTH letters. Then I will hit "A" again and then hit "V" it will work...
    Weird huh..
    Anyone else expierence this?
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Yup, what happens to me is because at the moment im running a pretty old comp, when i hit "A" it freezes up for a few seconds while it finds all the songs with "A" in it. And if i try to press another button while its frozen then it comes up with multiples A.
    If you go into the settings you can change the search setting so that it only searches when you hit enter. This fixes the problem as it doesnt search for your string until your ready, not at every key stroke.
      OHHHH!!! Thanks man... See I'm using a skin that has a full screen keyboard so I didn't know it was doing that. Totally makes sense though..
      I'll turn that setting off. Thanks again!
