Problem embedding freedrive in ME
  • Problem embedding freedrive in ME
    Hello,
    Freedrive won`t embed properly in ME.
    When i click GPS, ME pops a loading screen.
    Then freedrive loads and ME is @ the background.
    When i exit Freedrive i see the loading screen again, and nothing happens.
    Hope there is a solution!
    Greetz,
    Bunny
    VW Passat 2.0 95"
    Passatputer P4 3000, 512, 250g running CentraFuse
    Have you tried 1024X768? I was having the same issue w/Street Atlas and changing the resolution worked perfectly.
      I think this is a problem with ME. You'll probably notice that ME is chewing up 99% CPU while it's sitting at the loading screen. I had the same problem except on my system ME was using so much CPU that freedrive would appear to 'stall' during loading.
      I read on here somewhere that there is a similar problem with one of the other GPS apps (iGuidance?). Details here: http://www.mp3car.com/vbulletin/showthread.php?t=77836
      The next release should have a fix for iGuidance which will hopefully fix it for FreeDrive as well.
      1998 Toyota Supra RZ-s TwinTurbo
      BOOST - In-Car Entertainment System
        ok thanks, i`ll stick with Mapmonkey until it`s fixed.
        VW Passat 2.0 95"
