playlists.runok
  • playlists.runok
    when i try to play certain files i get an error message
    an error occured in playlists.runok : : Error number 0 click ok to terminate the application.
    WTH is this???? any cures
    figured out what causes the problem, when i try to load a .wma file then load another file after it it will give me that error, but if i load a .mp3 and then another file after it, i get no error, so i guess the question is, why cant i get it to play .wma. i added the extension but still nothing.
      It was a while ago since I set this up on my CarPC but I do remember that winamp requires a plug-in (codec) to play .wma files. There are two solutions and I have done both with the latter as the best solution:
      1. go to winamp.com and find the plug-in that plays .wma files and it should work then
      2. use iTunes or similar prog to reencode the .wma files into .mp3 files
      Solution no. 2 is the best because it definetely works and ME can read the id3 tags from the files while with .wma it cannot.
      '99 Volvo S80
      Carputer install progress: ++++++++--- (80%)
        thanks, i did number 2 not too long ago, doesnt take too long to do so i cant complain. thanks though
          Media Engine... converting people to open standards, one .wma file at a time.
          '01 Chevy Xtreme Stepside (pics)
          FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
          WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
          350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
            hehe.
            Maybe there should be built-in support for FLAC then.
            1998 Toyota Supra RZ-s TwinTurbo
            BOOST - In-Car Entertainment System
              I believe I added ogg and flac support sometime in 2003.
                That's why it doesn't work for me then. I'm still living in 2002.
