Vista?
  • Vista?
    I am researching to see which FE I like. Does this open with Vista? The error I get is "could not reference DB_update.exe. Ive tried to open it in compatibility mode, but no go.
    2007 Mazda 6
    Planning..............[10%]
    Purchasing Parts...[0%]
    Install.................[0%]
    Bugs...................[0%]
    Incomplete
    I've not tested MediaEngine with vista. Personally I don't like vista. I know this may sound backwards, but Vista is just "too much" for a car environment. I'm working on a XPE setup (XP stripped down) and its still *almost* too much.
    The front end apps available are not going to take advantage of vista's new "stuff". You might be better off using XP for now. You probably won't have hardly any issues.
    Get MediaEngine !!!
    Media Engine Download
      I dont really want vista in my car. But my laptop has vista, and I am trying to figure out what fe I like. I havent really found one yet. I just wanted to look at it on my laptop.
      2007 Mazda 6
      Incomplete
        Media Engine does not work with Vista from my research
          CentraFuse will work with Vista.
          Check out my CARPC: Project Diamond Plate
          Quick Reference:
          CPU Electrical Specs
          Power Supply Calculator
          Video Connections for newbies
          Temperature Converter
          Voltage Calculator
            i have got media engine to work with windows vista, you have to remove the permissions from vista (the annoying allow and deny boxes in vista). to do this you need to go into control panel then goto user accounts icon and click it. then go to turn user account control on or off and untick use user account control (UAC) to help protect your computer and press ok this will require you to restart the computer but once this is done you need to reset the media engine db_update.
            i can get media engine to work fine except the videos are not working.
            the added bounus of removing the permisions is that now it doesnt ask every time you want to open programs.
              +1
              vista is a pig, both for resources (you NEED at least 2 gb ram for ti to work smoothly), hdd space(it takes at least 15gb just for the os!!-xp standard takes 2-3gb..)
              don't even get me going on UAC...
              next project? subaru brz
              carpc undecided
