ME 2.1 and iGuidance
  • ME 2.1 and iGuidance
    I like this new version, has some good features. But it doesnt work to well with iGuidance . Because iGuidance has a disclaimer that pops up before the program loads, once you hit the OK button on the disclaimer window, ME switches back. Oh well, maybe this will be fixed in the near future.
    Otherwise... IT ROCKS.......AGAIN.......OF COURSE
    Boo-urns... same problem here with Routis
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
      so i was on IRC yesterday and saw carcomp is trying to get your problem fixed. He has made a test app to try to deal with programs with a splash screen. So hopefully the next update will fix the problem
      '98 Explorer Sport
      80% done
        I have the same problem using Routis 2004.
          The way to do it is, to allow a certain amount of time to find the window to focus on by title, and be able to input the title of the window manually. So if you set it to wait 10 seconds to get focus, you have time to hit the OK button to acknowlege the disclaimer window, or if you hit cancel it will time out and go back to ME. In carbox, this works great. The only thing with carbox is that youhave to have carbox in the same directory as routis or iguidance for either software to work. maybe carcomp will read this and make changes by the next release.
          This is all that keeps me from using ME 2.1.
            i know he had a test app out for people to try on all apps with a splash screen. So this problem will probably be fixed in the next release.
            http://www.mediaengine.org/index.php?bugs
            check out that link.. your bug is the first one and its listed as resolved
            '98 Explorer Sport
            80% done
