Windows Media Player and ME 2.1
  • Windows Media Player and ME 2.1
    Gday,
    I've just tested out me 2.1 and was pretty impressed with the feature updates. The only problem I have with it is the fact that it uses winamp as a music engine instead of 2.0's WMP. Most of my music collection is in WM9 lossless and therefore is not compatible with the winamp engine.
    Is there any way I can set ME 2.1 to use WMP??? Would be sooo good if I could get that to funtion.
    Thanks for your help,
    Dave
    Ya re-write it!!!
    New CarPC on the way again I think. I miss my old one!!!
      Just use ME 2.0, it was based on WMP.
        Winamp can play WMA Lossless Files with a simple change to the preferences. To make it play just do this (I'm using Winamp 5 so it may be different for others):
        1. Go into the winamp preferences.
        2. Click on "Input" listed in the "Plugins" section.
        3. Click on "Nullsoft DirectShow Decoder"
        4. Click on Configure.
        5. add ";WMA" to the extension list.
        6. Click OK
        7. Click Close
        8. Play all your WMA Lossless Files
        Originally posted by kingo102
        Gday,
        Dave
          No Matter what I try I cannot get my wma Files to work in the newest media engine????
          I've added the file extension,(in winamp and media engine)
          They show up but do not play?/?
          SOMEBODY PPPlease Help!!
          Thanks Gang
          Z3PC
            Thanks Gang
            Did you add it to your regular install of winamp or the winamp in the M.E. directory ?
            [H]4 Life
            I'm a lesbian too.
            I am for hire!
              I don't have a regular winamp install,
              and I did it to the one in the ME directory.
              I'm having the same problem on my home machine as well as my carpc
              any other suggestions??
              Thanks for your response
              Z3PC
                I don't have ME installed at the moment, if I get a chance I'll look around.
                Frodo
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
                  thanks Dude
                  Z3PC
                    is ME the best program to use?
                    Z3PC
                      If any one Has the answer to this problem I really appreciate your help
                      Thanks!
                      Z3PC
                        Me is in my opinion the best
                        -Jason
                          Here's a strange thing.
                          I got me2.1 to play wma on my laptop but cant get it to work on my home pc nor my carpc.
                          Exact same settings and versions??????
                          WTF?????
                          Thanks for any responses
                          Z3PC
