Wont load!!!!!
This topic is closed.
  • Wont load!!!!!
    When I try to load MediaEngine 2.1, the status gets to "Loading Movie Player" and then the program restarts.. Thats as far as it gets... it just keeps restarting.
    Any ideas?? I'm in WIN98SE
    Originally posted by CarComp
    Did you make sure to uninstall the old version of mediaengine before you installed 2.1.4?
    It was a first time install of MediaEngine.. I installed WindowsXP Pro and it worked fine, but I much rather use WIN98 because its a bit quicker on my system..
      3/15/04 12:01:14 AM - db pass complete
      3/15/04 12:01:19 AM - Winamp was restarted
      3/15/04 12:01:24 AM - An error occured in settings.DoneButton_Click : Component 'mswebdvd.dll' or one of its dependencies not correctly registered: a file is missing or invalid : Error number 339
      3/15/04 12:01:24 AM - MediaEngine terminated correctly by user.
      3/15/04 12:01:27 AM - There has been an error in astart.form_load : Component 'mswebdvd.dll' or one of its dependencies not correctly registered: a file is missing or invalid : Error number 339
      and it just keeps looping..
        Installed new version of DirectX and now Im getting an illegal operation:
        "MEDIAENGINE cause an invalid page fault in module MSDXM.OCX at 0167:1d351b43"
          The reason this is occuring is is because the installer is not registering mswebdvd.dll file. The solution to this is to register that file by either finding it on your computer, or downloading it here. Once you have the file, put it in the c:\windows\system32 directory and use REGSVR32.exe (a component of windows) on the file. It will say it succeeded if you have done it right.
          Get MediaEngine !!!
          Media Engine Download
