Adding file syncronisation to Media Engine
  • Adding file syncronisation to Media Engine
    Dear all,
    (Another idea which has probably already been discussed). I guess most people have their carputers starting and sleeping pretty much based on the ignition state. Based upon this assumption, if I want to copy files onto my carputer from my home over a wireless LAN, the car would have to be left running.
    How about adding a directory synchronisation system to Media Engine.
    For example:
    On my home PC (call it home) I have a share called Media Engine:
    //Home/MediaEngine
    It would be good if I could be sat in my car outside my house and select a Synchronise option in Media Engine. This option would connect to the configured share //Home/MediaEngine and would synchronise the Media directory on my carputer with the //Home/MediaEngine directory. Based upon the directory //Home/MediaEngine, it would either delete files from my carputer or add files to my carputer. Once the files are synchronised, the db in Media Engine could then be updated accordingly.
    The beauty is that I can manage the files (i.e. add / remove) from they comfort of my home, and then when I go out to my car, before driving off I would just sync up.
    Thoughts?
    Again, pretty easy functionality to add and I don't mind developing this if I was able to assist with development of Media Engine.
    Regards,
    Andrew
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
    I believe this functionality is somewhat built into media engine...I noticed there is an option for sync folders within the media engine control panel. I haven't tried it yet.
    It would need to operate like a roaming profile does in a windows enviroment. When files are updated on either end...whichever contains the most recent updates is the master copy. That way if you ripped a cd on the road etc....it would sync back to your server.
    Asus Pundit Barebones PC
    7" Lilliput LCD
    P4 2.8ghz 512mb 120gb
    Windows XP Pro, VOICES
    Sony Xplode 10in Sub, Rockford 600w amp
    Pioneer 6x9's and 4x6's, Kenwood 4ch amp
    Black Widow Alarm with Pager
      Isn't this exact feature already built in to Media Engine? Its under AutoSync and it has source and destination folders. Unless I am missing something...
        Ok, so I win the prize for having a blonde moment.
        Just taken a look and yes, it's there... What would be useful is if it could be accessed from the main screen, rather than having to go into the cnfig screen. The main reason I think this would be useful is it would be used quite frequently.
        06 Volvo XC90
          I have tried the Autosync in version 2.1.0.
          There's no errors when there is no files in the Sync Directory,
          However, I tried putting a file to sync, it just exits ME totally.
          Debug log shows.
          26-Mar-04 12:58:53 PM - An error occured in settings.CopyFiles : Overflow : Error number 6
          Using WinXP, new installation.
          Carcomp, are you reading..?
          MediaCar
          Girder with Igor plugin
          EPIA-ME6000 w 256MB DDR
          Morex 55W PSU
          12VDC Regulator
          IBM DJSA-220 20GB
          90% completed in a plastic case (8"x10"x2.5")
            SportivoWISH, are YOU reading ???? [3rd item (Sticky) on forum]
            Bug-reports can only be done via the ME-site bug-report option.
            ---[ This space intentionally left blank ]---
              YES, I'm reading from everywhere... haaa
              Apparrently, someone reported about this over at bug-report section and there was a reply given. Please read it yourself.
              MediaCar
              Morex 55W PSU
              12VDC Regulator
              IBM DJSA-220 20GB
                Note: an alternative to this would be using a feature built into windows called “offline files.” This will allow you to sync when logging on, off, or when you choose to.
                ry
                7" Lilliput LCD
