Scroll arrow size adjustment?
  • Scroll arrow size adjustment?
    Hi all, I have been using ME for a couple of months now and it is GREAT! however, there is one little annoyance I want to try and fix.
    I use a touchscreen as an input device to control ME and sometime when I try to scroll up or down in the MP3 directories my fat fingers may be a mm or two off and accidentally 'click' on a song rather than the up/down arrow. Is there any way to increase the size of the touchable area of the arrows? I never us the far right side of the screen to 'click' on songs anyway so if the up/down buttons touchable area was around 2-3cm wider it would be much easier to scroll the lists.
    Anyone know how I can change it? or would i need to somehow hard-code it in? (my VB skills date back to 1999 - 2000, so they are VERY rusty). I have tried mucking around with resolutions but to no avail.
    Thanks in advance.
    - Ed
    Car PC v1 - 1999 - 2000
    DOS 6.22 - MPXF - 2x16 LCD - 6.4GB
    Car PC v2 - 2002 - 2006
    XP - 7" wide/touch - GPS - Tank batt relay - 100GB
    Car PC v3 - 2008
    XP - 7" wide/touch - GPS - 802.11g - FM/XM - OBDII - WWW
    [||||||||||||||----] 80% complete
    please, dont everyone reply at once!
    Car PC v3 - 2008
      That should be able to be set in the desktop properties. Like where you set the color of the title bars, icon background, etc. Should be in your display control panel. That's where it is with 2000/XP
        if all else fails i suggest filling your fingernails into dull points and using it as a stylus
        note: "only for obscenely obese fingertips"
          I meant the scroll bars in Media Engine, not in Windows. You will see the when you click on 'Music' and if you have too many MP3's in the directory to fit one screen.
          Car PC v3 - 2008
            How did you get the arrows working with the TS???
            Where did you touch to get a reaction?
              The scrollbar size is a ratio to the screen size.. You can't change them
              Get MediaEngine !!!
              Media Engine Download
                I was hoping you wouldnt say that
                Fry, I touch on the arrows and they work. But if I am a LITTLE off the arrow (which happens due to my fat fingers) then the song that is in line with where my finger 'clicked' starts to play, which is very annoying.
                Car PC v3 - 2008
                  Just revising this post, im wondering if its possible to REDUCE the size of the clickable area for a song. So rather than the clickable area being the entire line accross the screen for the song, it take up 3/4 of the screen instead.
                  this possible?
                  Car PC v3 - 2008
                    dont think so...
                    could try playing with the skinning prog but dont think youcan do it that way either,
                    youcan however,....
                    reduce the size of the text of the titles of the songs (get that??!)
                    thus maybe, reducing the clickable area....
                    open the .skn file in notepad and have aplay around withfont sizes etc....
                    hope this helps.
                    on2
                      thanks OriginalNick2, ill give that a go
                      Car PC v3 - 2008
                        Did it work???
                          dont know yet, i took my carpc out of my car yesterday and im doing a full format/reinstall
                          will let you know when ive tested it out
                          Car PC v3 - 2008
                            I can tell you that it wouldn't work. I think media should have just made that area exclusively for scrolling.
                            One more thing. For the people that has problem with touchscreen and that scroll, it's because you had your touchscreen properties set either to "Click on touch" or "Click on release". It does not work with either settings. You'll need the "normal" settings to make it work.
                            Sometime in the future, when I'm fabing my console, I'll make 2 buttons on the right side of my screen that linked with those arrows.
                            Is it possible to make the scrolling actually scroll instead of paging? I know paging is faster, but it just doesn't look to appealing. maybe holding on arrow to page?
