ibus? anyone use...
  • ibus? anyone use...
    IBUSComm.exe or another app to pass key strokes to MediaEngine from BMW wheel controls?
    i dont use it, but i would be interested in using it. Where can i get more information on this?
      djgman,
      i was thinking the exact same thing. havent found a specific app yet but this site has a lot: http://autos.groups.yahoo.com/group/HackTheIBus/
      where do you get IBUSComm.exe ? google had no results.
      TIA
      gaphix.com
      MSI KM4M MicroATX, Duron 1.6, 512 Micron 2700, WD 80 7200 8mb, Pioneer 120S, M-audio 7.1 pci, Targus USB 2.0 hub, 3com 11a/b/g pci, PNY FX5200 AGP 64mb, Lilliput 7"
        ah.. its included BeBox. can be found here
        check the BeBox.ini for some german to english insite.
        the ibuscom.ini has all the setup for the messages and commands. so far, unfortunatly i cannot get it to work with anything bebox.
        http://sourceforge.net/projects/beboxmp3/
          For steering wheel volume buttons :
          add this at the end of the IBUSCOMM.INI file :
          [ID:STW_PLUS_PRES]
          MsgTemplate="50046832111F"
          Label="S. Wheel + Press"
          Parse=True
          KeyboardMap="{+}"
          [ID:STW_MINUS_PRES]
          MsgTemplate="50046832101E"
          Label="S. Wheel - Press"
          Parse=True
          KeyboardMap="{-}"
          This will declare 2 msg. Set the right key you want to map (I have
          set these to "-" and "+" here).
          Then Add these 2 lines in the [IBusIdsDefine] section
          STW_PLUS_PRES=159
          STW_MINUS_PRES=160
          You should be able to catch steering wheel +/- buttons pressed
          messages.
            Sorry to revive an old thread - but I've got Rolf's gadget installed and ibuscomm as described here:
            http://www.mp3car.com/vbulletin/showthread.php?p=412827
            I've set it up to control winamp, but I am far from getting it to work properly.
            ...Ibuscomm properly reads button presses, but not all commands properly activate winamp. For example, ALT-F4 does close winamp but if I set a keystroke that I've configured as a Winamp "hotkey" doesn't work (example, winamp hotkey "f" skips forward, but setting Ibuscomm to send keystroke "f" or "{f}" does not work). It works if I push the "f" button on the keyboard but does not work if ibuscomm sends that keystroke...
            Secondly, is there a tutorial or document about ibuscomm.ini? I wonder:
            * What is a "MsgTemplate"?
            * What is the [IBusIdsDefine] section? What do those values mean?
            * How do I map the other buttons on my e39 BMW steering wheel, and the other buttons on my widescreen nav (clock, phone buttons, etc.)?
            Many thanks,
            Paul
              Hi I'm working on my Ibuss -> Car pc interface in my X5,
              and currently I have the volume working; I'll be coding the keystrokes to control the next/prev/mute this weekend.
              Currently I just modified Varans free software to control the master volume when you press the up/down volume on the steering wheel. So if you download the IbusMonitor.exe from my page and run it in the background it should work.
              http://www.geocities.com/isaakian/isaakians_page.html
              I had to rename the extension to .txt to get it to upload~
              Not sure if this is anyuse to anyone, but if so enjoy. I'll update it when I get more stuff working.
                Link : http://www.geocities.com/isaakian/IB..._me_to_exe.txt
                  link is broke
                  e46|700tsv 2005 model|sb51g xpc2.4ghz opus 150|I-bus|XM Direct&cables | slim slot USB DVD-cdrw|Hawking 54g|iGuidance 2.1-HoluxGPS
                  sold it all... :-(
                  Coming Soon - 2007 BMW 335i UMPC install
                    http://www.geocities.com/isaakian/IB....rename_me.txt
                    right click... save target as...
                    sold it all... :-(
                      Sorry; I updated the file name
                      The source is also available at my page
                        Nothing better than reviving a 3 year old thread, but just in case someone knows the answer, ive already started a few threads myself but no one knows
                        [ID:STW_PLUS_PRES]
                        Parse=True
                        KeyboardMap="{+}"
                        [ID:STW_MINUS_PRES]
                        Parse=True
                        KeyboardMap="{-}"
                        STW_PLUS_PRES=159
                        STW_MINUS_PRES=160
                        messages.
                        I want to map the Phone button to a keyboard letter (F3) as opposed to the setting that says "MUTE" anyone have any experience or suggestions this is the code i would like to change
                        Code:
                        ;Steering Wheel PHONE Press
                        [ID:STW_PHONE_PRES]
                        MsgTemplate="5004C83B8027"
                        KeyboardMap="MUTE"
                        Something like this i imagine:
                        Code:
                        [ID:STW_PHONE_PRES]
                        KeyboardMap="{F3}"
                        Anyone got a clue?
                        CarPuter Progress:
                        Planning:-----> [||||||||||] 100%
                        Hardware Buying:-> [||||||||||] 100%
                        Software:-----> [||||||||||] 100%
                        Installing:-----> [||||||||||] 100%
                        Current Project= Making skins in photoshop...
                          talk to radiotrib over at digital-car.co.uk he'll know! (just got your private message)
                          Current:
                          [BMW E46 ///M3 Convertible]
                          Previous:
                          [BMW E31 850CSi]|[BMW E39 535i]|[BMW HVAC Research]|[IBUS Scrolling Text]|[BMPuter]|[Velocity]|[TomTom]|[Vision]|[Space Navigator Driver]|[Super Fast Boot]
