ME 2.3.2 hangs on "LOAD" screen
  • ME 2.3.2 hangs on "LOAD" screen
    I can get ME to hang on the "LOAD" screen when I go from a mpg video clip to "home" button. It does this every time. Application is still running but I have to close it manually with ctrl-alt-del.
    I also have an issue with DVD video. When I run a DVD and then select another video file on the HD, I still see the last pic frame frozen from the DVD movie...sound is ok but no pic.
    Is these problems codec related?
    Most of your issues have been fixed - I'll send you a PM with the link to download the test build.
    The only issue I haven't resolved is reaching the end of a large MPEG stream - but I'll try to get figure this out sometime over the weekend or early next week.
    '01 Chevy Xtreme Stepside (pics)
    FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
    WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
    350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
      im having the same problem for freezing at the loading screen while exiting a movie.
      can u pm me the same link?
      thanks
        Thank you very much! Works better now....great software!
          Yes i have the same problem with 2.3.2 also my dvd's the picture seems to pause after 5- 10 mins of playtime but sounds continues.. only in ME not when playing in an external app. hope it is the same issue
            can i get that link too phat .....thanks alot man
            my load screen freezes when i try to run iguidance
              Any chance of me getting a PM phat? I thought it was my computer setup that's causing the "loading" screen to hang when I changed my Panasonic DVD drive. But it looks like a software issue instead... Would really wanna test it too.
                lock up also
                Mine seems to lock up sometimes on load screen. can't figure out why. must by just me and my luck. if you have test one I can load I would love to do it..
                I don't care how I get there as long as it's fast....
                  Same Haning on Load Problem
                  Hey Phat, can i get the PM to the link correcting the haninging issue??? It is a real problem since I use a touchpad NCR Kiosk unit and there is no keyboard to ctl alt delete....
                  Thanks,
                  ken
                    I would be grateful for the update as well... I am having similar issues. Thanks! Love the prog!
                      Can i get the PM link to!
                      I have to stop the car and open the trunk, each time it freeses on the loading screen.
                        would like that one as well.
                        -Xenarc 700TS
                        -P4 2.0 GHz, DIN size, 512 RAM, 80 Gb hdd, DVD/CD
                        -Usb GPS, FM modulator
                        -OBD2 interface
                        -Frodoplayer & Destinator frontend
