How to control the wave output in ME
  • How to control the wave output in ME
    Hello, first sorry for my English I'm from Germany.
    Now my problem, I'm using Mediaengine in my CPC but i have a problem with the volume control.
    Because i use the sp/dif on my M10000 i need to control the Wave button in the windows settings for volume control is there a way to change ME to control the wave button instead?
    I hope you understand me. :/
    Do a search for Frodobaggins matchvol.exe this program should be placed in your startup folder.
    This program basically locks the master volumt and wave volume together. This is what i use and it works great. Has no interference with ME.
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
      Go into MediaEngine settings screen, click the Actions Tab, and make sure that your "Change Main Volume Only" box is unchecked
      Simple as that.
      Get MediaEngine !!!
      Media Engine Download
        I've tried both recommended solutions and I get som strange results. I'm using a Turtle Beach roadie usb sound card, but I ge the same results with onboard audio. Getting one of them to work right would be awesome, as it lets me get maximum range from my amps; really quiet to really loud.
        Matchvol works pretty good, but everyone once in awhile when changing songes the first second or so will be a little but louder, then it will go back to the correct volume. I thinks it mostly affects songs that start out full volume right away, like metal and such. When using iGuidance, the turn by turn directions lady will scream at me for the second or two as well.
        The "Change Main Volume Only" works good, until the track switches as well
        only now it gets really loud, and stays really loud. iGuidance workes well, untill I exit it, then my music gets loud again.
        Any Ideas?
        -ZtH01
        -ZtH01
        "It's my belief that my big balls should be held every night"
