Instalation problem
  • Instalation problem
    hey guys.... after installing im geting this error.....22/07/2006 3:27:39 PM - An error occured in astart.initAccSense() : Out of memory : Error number 7
    Any one has a solution?
    While trying out ME on a different PC, I came across similar errors. After some trial and error, I noticed that it only happens with certain skins at a high resolution.
    Use the default skin or set your resolution to 1024x768 or even lower like 800x600. This worked for me right away.
    '99 Volvo S80
    Carputer install progress: ++++++++--- (80%)
      Hi,
      got the same error with this function but with an error code of -MAX_LONG or what this hughe number is.
      What does that function do?
      I assume no display thing but the ignition/ACC power check within the serial port. But this is disabled by default.
        Hi,
        no replays, strange.
        Anyway. I installed a previous version of ME 2.x, enabled the ACC thing in the setup menue without connecting the port to anything, set it to 45min and it worked.
          I believe the issue you're seeing here is an error happening in another section of the app that doesn't have the correct error handlers.
          Try the executable listed in this thread and see if you have any different results.
          '01 Chevy Xtreme Stepside (pics)
          FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
          WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
          350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
