Error - First Time Use: Choose Display Playlist
  • Error - First Time Use: Choose Display Playlist
    Hi,
    I am using 1.76 and when I go to the MP3 option I get the above..
    Very strange - any ideas any body.
    Thanks In Advance
    Terran
    My Project Site
    Happens with everybody, use the plalist option and select a file first. Will play correctly from then on out
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      it happens when you first start the software for the first time. If it does it everytime you start it up then you might check to see if you have your hard drive read only or if for some reason its not creating the settings.ini file.
      The Grand aMP3 Project
      Car: 96 Pontiac Grand Am
      Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
        Doh ! Thanks that worked.
        Ayce
        My Project Site
          works everytime
          [H]4 Life
          I'm a lesbian too.
          I am for hire!
