Help required for media engine
  • Help required for media engine
    Hello friends,
    I am planning to put a screen in my carputer and media engine shall be the front end for this its a great software..
    have a few questions..
    a) When i hit the shutdown button it just restarts the comp.
    b) when ask to play mp3 it says "error cant find winamp press quit"
    c) Need the ability to fast forward / rewind a track when playing mp3 right now it just goes to the next and back. (using touch screen)
    Any help is good help.
    Mastero
    comeone creator help
    why does it restats and not shutdown when i hit the shutdown button
      i've only heard about this with win2k
      '98 Explorer Sport
      80% done
        i am working on win98 (SE) ...?
        Mastero
          Im using 98SE as well, when I choose shutdown in MediaEngine, it doesnt even shut down, let alone restart - the program hangs showing "Loading" in the center of the screen. I don't bother using this option.
          (=========-) 99% complete
          AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
          All jammed in external CDROM drive case.
          Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
            Could it not be Windows at fault rather than ME ? I have see this on the OS and there is a fix on the MS site.
            Terran
            My Project Site
              Er, no. Windows shuts down fine, just not from within Mediaengine, its definately an issue with the shutdown call used in Mediaengine.
                Just a thought...
                Terran
                My Project Site
                  I agree with you phil its a fault with ME call to shutdown ...
                  Also where can i get an open source so i can modify the same in VB6
                  Mastero
                    Did you already try updating the .exe as suggested in the first thread on this page?
                      yes i did update the exe... still no change ....
                      New discovery
                      VIS funtion button on screen doesnt work ....... works with key press feature... but once on the screen shows graphics then when hit the esc button on the keyboard .... Boom no more vis ...?
                      Check this out
                      Mastero
                        I also have the shut down problem with Windows Milliennium Edition. Media Engine just hangs, no shutdown at all. Its not the OS its Media Engine.
                        I was told to upgrade to 2000 or XP.
                        It's the cake having/eating thing.
                          Heh. Well the mediaengine shutdown code is written per microsoft's recommendations... It works fine for me and many others... I think it is a hairy deal... You must understand that mediaengine is meant to run in a car environment on a clean PC... Perhaps..
                          Get MediaEngine !!!
                          Media Engine Download
                            Can you post the code snippet ?
                            [H]4 Life
                            I'm a lesbian too.
                            I am for hire!
                              carcomp tumps up for your work !!
                              I am using the ME on a clean pc with only win98(SE) on it ...
                              Also the vis funtion has a problem ..... does nothing when you hit the onscreen button
                              Mastero
