IR Repeat Speed
  • IR Repeat Speed
    I know you can use the repeat speed to speed up the packet repeat on the IR remotes (I am using creative CMIR). But is it possible to make it as fast as holding down a key on your keyboard? So far with some tweaking, I got it faster than normal, but not that fast. Any tips??
    BTW: I am only using the built in IR functions in MediaEngine. Would I beable to get it going faster with a program like Girder? thx
    if you use girder, you will be limited to the repeat rate of the remote itself. My remote sends out repeat IR signal quite quickly and if i have girder set to "0ms repeat delay", it is at least as fast as holding down a key on the keyboard.
