Whats the status on V2
  • Whats the status on V2
    I was just wanting to know how the testing and refining is going on V2. There doesn't seem to be a lot updating on whats going on. I mean fear enough, you have lives and jobs (i presume), but it nice to keep the community up to date.
    JUST A THOUGHT.
    The passing of all roads end up being a life time of regreat which leads the past to the future.
    We are, will have and forever will be...
    But not tommorrow!
    i'm also curious, got everyting installed except the software. Please let someone give a deadline/estimated date.
      I think they are in the process of ditching winamp for WMP.. so give them some more time
      '98 Explorer Sport
      80% done
        Now if only they could write in Wizard's relay controller we'd be rocking!
          NOOOOOOOOOOOOO!!!!!!!!!!
          I must have my milk drop plug-in!!!!!!!!!!!
          Aura MR62 (F and R)
          My Current MP3s
          IamDefiler.com
            ofcourse, but an estimated date like august or september would be nice.
              I must have my milk-drop visual.
              You should send an email to the creator and see if he/she can port it into a WMP visual, because i to like that visual.
              But not tommorrow!
                why don't they just make it hybrid, using WMP or Winamp? Whichever the user prefers
                  Because the APIs will be completely different, and every future change to the media playing will need to be replacated in both their WinAMP and WMP interfaces.
                  GingerPrince
                  Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
                  Carputer Install - http://www.stuffandting.com/carputer/
                  CarBox Software -- http://www.stuffandting.com/carbox/
                    You want to know whats up with 2.0? I tell you now!
                    What we got here is a situation of inadequacies (sic) with winamp. One thing winamp LOVES to do is steal focus from m.e. Also it does not like to cooperate with visualizations, and seeing that there is only 1 way to control vis, its almost pointless to try to. (Hence the spotty exit vis in 1.77F)
                    We are using the WMP control because it is WAY FASTER... It will run in a different process thus freeing up the m.e process for m.e events. (ever load a big playlist in 1.77?) We will also be able to control the playlist with unprecedented control. We may lose a few plugins, but we gain stability, control, and most of all a better way to improve future versions of m.e. The wmp control is more complex than you can imagine.
                    We ARE going to put GPS into 2.0. Thank hijinks. It will be mappoint based, so you must have a copy of mappoint installed if you wish to use GPS. It will work with all NMEA compatible GPS receivers.
                    We are also now supporting all the APM modes... Standby, Hibernate, and ShutDown. You enter the mode by using the old "shut down" button, but you set up how you want it to function in settings.
                    We are also making sure that ALL the old skins are supported. If there are "bits" missing that 2.0 needs (new icons and stuff) m.e 2.0 will fill in the holes with default icons.
                    Thats about all for now.
                    Get MediaEngine !!!
                    Media Engine Download
                      With these WMP controls, will we be required to have a certain version of WMP? (Like 9.0?) Last time I fooled around with WMP controls they were very basic (WMP6 or so).
                      2000 Ford Focus ZTS
                        Thanks for the update CarComp, and thanks for all the work that you put into that software. It's really amazing. I'm studying Software Engineering and I don't think that I'd be able to program such a complex program...
                        Now the final question... WHEN WILL IT BE AVAILABLE?
                          Mappoint? Who makes that, MS?
                            Yes, MICROSOFT makes it...
                              oh hell I bet there will be people whining about having to use a MICROSOFT product to use GPS...
                              Cordell
