ME1.x Help!
  • ME1.x Help!
    Alright, I downloaded and installed ME tonight, did a little configureing and rebooted. I also installed a display driver (That needs massive config!) and so I can't read 1/2 of the screen because its running in 16 color (Approx) mode.. ME is the only thing that boots up, it goes right to it. I can't get it to let me do anything such as start explorer.exe so I can change the control panel settings. Can someone help me make ME not auto-load?
    Thanks!
    1993 BMW 325is - 15.2sec
    in windows 2000/XP just press ctrl-alt-del and bring up the task manager, from there run explorer.exe
    in win9x there was some way to bring up the run command when not in explorer (start button - R maybe?) otherwise just in DOS you can change the shell in the win or system.ini (god haven't used win9x in so long!)
      SiGmA_X, load up the ME control panel and make ME not be your default shell. Somehow you clicked that option.
      '98 Explorer Sport
      80% done
        UncoCow - Doesn't work. "Cannot find explorer.exe"
        hijinks21 - Can you explain where that is in the CP?
          Ah,got it. Thanks.
