Grrr Me 1.7.7g
  • Grrr Me 1.7.7g
    thats the executable update IIRC
    neway, all has been going well with my skin, but for some reason when i click anything other than my music button, the ME starts to flash quickly, it doesnt do it on other skins so y has it (just decided) to start doing it on mine?
    post your skin and i'll see if i can debug it.
    the skin maker is still very buggy.. chances you skn file is not complete
    '98 Explorer Sport
    80% done
      i checked it with another skn file n everything seems to b ok, ive not added the radio button yet or the shutdown button, but it was working fine the other day, should i get these butons in then try it? (only thing that works ATM is music and external app) movies and playlists dont!
        ya you can try.. i've noticed that sometimes when you dont have a font or color set it does that.
        '98 Explorer Sport
        80% done
          nope not worked, had a look thru the skn, it seemed pretty *****ed TBH sorted that out, was missing an outline colour (which in skin maker it wont let you set!) and the odd font which is not fixed, you got MSN messenger? PM me ure addy and ill send the skin your way
            shutdown works music works radio works external app works
            MOVIES AND PLAYLISTS DONT WORK!
              just found alot of this error in the debug log..
              05/09/2003 13:02:51 An error occured in playlists.artistlistitem_Select : Invalid property value : Error number 380
                mine does the exact same thing on the interface skin...
                but only on folders with more than 15-20 items (don't know exact number)
                it only started doing it recently, it had worked fine on the interface skin for ages....
                might try the default skin then see if it fixes it
                  any other skin works fine but mine, (i only have default and audi installed)
                    zip up your skin files for me to debug and post them to this thread or email them to me
                    mzupan at meso.com
                    '98 Explorer Sport
                    80% done
                      ok will do, you'll have to excuse the skin dir its a bit messy lol
                        sent
                          i checked it out.. everything loaded just fine for me. I'm at work right now so i don't have any mp3s on the 2 windows computers here so its not a good test.. but the playlist window opened up and everything. I didn't install any of the fonts either. So the problem could be the font? or its just not listing any directories so its erroring out for you but not me. I'll test more when i get home
                          '98 Explorer Sport
                          80% done
                            ill reset the dir's might fix it
                              just done all that and tried reinstalling it but its not wantin to work
