My changes to ME v1.7x
  • My changes to ME v1.7x
    I have been playing with the MediaEngine 1.7.7 source code, and have added a few features that I want for my needs.
    They are as follows:
    1. Ability to load *.ogg files, as well as include them in directory syncing
    2. Option to display Time Remaining or Time Elapsed
    3. Option to display Total Track Time
    4. Ability to resume playback of music files from the point you were last at (providing you Exit to main menu, won't work if you pull the power)
    5. Ability to choose whether to shut down, standby or hibernate the PC (when running 2k/XP)
    **Added 23/09/03**
    6. When browsing in Playlists, will return to the last selected directory, rather than the beginning of the list
    **Added 29/09/03**
    7. Update to #6, it will now go up a directory, rather than returning to the same directory
    8. Application no longer hangs when returning from External Application
    9. Visualisation button on MP3 screen now starts Vis
    10. Ext App button on MP3 screen opens up External app and leaves music playing
    Bugs I know about and that I've fixed
    **23/09/03**
    1. When selecting a new playlist it now starts playback from begining of song, not wherever the last saved position from last song was. Fixed
    2. When moving forwards in directory listing and not moving up/down it would crash. Fixed
    To set these options you should be able to simply the executable over the existing file (backing up just in case), and going to the Settings menu. From here, once you select the options, it will make the relevent sections in the settings.ini file. (You don't have to delete your existing settings file, which should make it an easy upgrade). You will find the Shutdown options in the Directories & Startup tab, and the rest in the Appearance tab.
    I have tested this on my production machine, and all seems to work as it should. The existing problem of exiting to the main menu from the playlist screen still exists, so that's nothing to do with my coding! If there are any more problems, please let me know, and I shall try my best to fix them.
    I hope this adds some more support and features to ME1.7x which will tide some of us over til the release of 2.0
    You can download the updated EXE file from http://www.my105e.com/carputer/MediaEngine.exe
    Enjoy!
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Doesn't Work in my Me
    I replaced the .exe file but appear a error like this: "Window cannot run this program because it is in an invalid format"
    Thank's
    2008 Honda Civic LXS
    Zotac 630i
    2Gb DDR 800
    500GB
    Lilliput 629 (DVI)
    WinXp Pro (Customized)
    Holux
    M2-ATX
    3D Connection
    Centrafuse
      sounds like you didn't download it in binary form
      '98 Explorer Sport
      80% done
        I don't think the whole thing is there. Its only 159kb when the regular ME .exe is 1.01mb.
        2007 Tahoe
        Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
        My Install
          It's not, that file downloads as 159kb
          [H]4 Life
          I'm a lesbian too.
          I am for hire!
            My apologies.
            Seems my FTP client timed out when uploading from my laptop.
            I have now uploaded it in it's full form, and should download as 1.02mb (as there's some extra code it's a touch bigger than CarComp's previous release)
            Garry
            www.aimee.cc
              Originally posted by Confused
              My apologies.
              Garry
              can you relese the source code to ?
              Julle
                Looking good man!!! Thanks for some of the features I was looking for. Any chance of adding other movie file type support?
                Aura MR62 (F and R)
                My Current MP3s
                IamDefiler.com
                  Lemme know some file extensions you want to play, and I'll add support for those extensions, but whether it will actually play them, you'll have to find out for me
                  Julie, I will chuck the source code up when I've finished playing
                  Garry
                  www.aimee.cc
                    .dat support shall be nice
                    mastero
                      .MOV is really the big one I would like.
                      Aura MR62 (F and R)
                      My Current MP3s
                      IamDefiler.com
                        From looking at the source code, integrating QuickTime support into Media Engine 1.7 would be quite a project...
                        MY CAR IS FOR SALE!
                        See My Project Page for Details - 2003 BMW E46 ///M3
                        Custom Dash Monitor Housing - OEM Fitment
                        Custom Overhead DVD-ROM Housing in Headliner
                        BMW I-Bus Integration
                        My homepage with many other fun projects!
                          could you please do something about the shutdown in win98se..thats my os. when i hit the shutdown key it just logs off and back on .. PLEASE NEED THIS ASAP !
                          It shall be nice if i could send it to standby mode.
                          mastero
                            One other thing...When scrolling through songs or movies, is it possible to have the highlighted bar stay in the middle of the list so it won't go all the way to the bottom of the screen? This way you can see the next few songs/movies in both directions.
                            Aura MR62 (F and R)
                            My Current MP3s
                            IamDefiler.com
                              AS far as i'm aware .mov (quicktime) is basically non-existant, there is no activex avaliable from apple for Win32 developers to use except for a NON-FREE one avaliable here http://www.skylark.ie/skylight/default.asp.
                              I have heaps of movie trailers (in .mov format) which i'd love to play in my CarPC, but i can't find a lot of info for implimenting mov playback in a windows app.
                              We are, will have and forever will be...
                              But not tommorrow!
