Irman now works after standby!
  • Irman now works after standby!
    Just found this. http://www.irassistant.com/dotcom/v_current/ . If you download the Powersafe from the downloads you can get your Irman to work after standy/hibernation.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
    good job Naamanf, I'm sure a lot of people will be glad you found this
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      Just downloaded and installed this IRAssistant, irman.dll and powersafe.dll.
      Activated it and now ME 2 wont load. Pops up with a couple of error messages, something to do with one of the ME exe's. Will write down these tomorrow.
      What have i done wrong?
      Volvo C70 - Installation in progress *gulp*
        Irman needs to be disabled in ME. Load ME with IRAssistant off. Then turn Irman off in ME. Load up IRAssistant, program it with the functions you want, then reload ME. Should work fine after that.
        2007 Tahoe
        My Install
          Do you have to use IRAssistant to control ME? thus not use the IR config in ME.
          I noticed theres an option to load an application in IRAssistant and at the same time turn IR off so the application can use the port for IR. This seems to work fine with ME until I put windows into Standby, on reloading obviously ME has the IR port open so IRAssistant doesn't have control to re-start the port.
            I use IRAssistant to control ME. I leave the Irman control in ME disabled.
            The whole point of using IRAssistant is that it can reopen the port for its own use after standyby/hybernation. Now my be if the wonderfull coders of ME look at the DLL for IRAssistant they might be able to incorporate it into ME (hint hint).
            2007 Tahoe
            My Install
              That would be very nice and useful with ME (hint hint again)
              So have you set up the keyboard actions under ME and configured IRAssistant to fire these keyboard actions with a remote or something?
                Thats exactly what I have done. I have a PAC SWI-X hooked up to my steering wheel buttons. I have pretty much full control of ME with my steering wheel through the SWI-X/Irman/IRAssistant.
                2007 Tahoe
                My Install
                  Ah, good stuff.
                  Will have to play around with IRAssistant then and figure it all out.
                  cheers!
