FM Radio - remove stations? And line-in mute
  • FM Radio - remove stations? And line-in mute
    Hi
    Just a question and a comment..
    Can you REMOVE stations from the FM list? While I was trying to get it working in XP I managed to add lots of stations and now realise I can't get rid of them, unless I'm very ignorant... Also can you tag a station with a name? That would be much more user friendly than just showing the frequency.
    And also when the radio isn't in use (eg when you leave the radio screen) there should be a way to make it mute the line in that the radio connects to, because the USB tuner appears to be quite noisy when not in use (and that's annoying). Yep automuting would be useful.
    That's about it..
    89 Celica, CarPC installed, 1st bday :)
    http://www.fishy.net.nz/carpc/
    • MediaEngine
    • Epia V8000
    • 80GB WD 7200RPM HD
    • Xenarc 700TS
    • SB Live
    • Opus 90W
    • CIMR100 remote
    • Deluo serial GPS
    • D-Link USB radio wired to power antenna
    I have done this. auto muting shall post the exe ...
    Also the FM stations can be edited with the stations.txt in the ME folder use word pad
    mastero
      Oh.. Thanks! Yeah please do post the exe. How does it work?
      • MediaEngine
      • Epia V8000
      • Xenarc 700TS
      • SB Live
      • Opus 90W
      • CIMR100 remote
      • Deluo serial GPS
        Why doesn't someone submit changes like these to myself or CarComp so they're added to the official release, instead of having a thousand different custom made binaries floating around???
        OrangePeel - Guessing that you're asking about MediaEngine 2.0, the fm 'favorites' (presets) are stored in a file named presets.lst now. You should also see an option when you load up the MediaBrowser from the main menu to edit your radio station presets tags. You will however have to delete unwanted ones manually in notepad.
        '01 Chevy Xtreme Stepside (pics)
        FIC K7MNF-64 / Athlon 3200 | 256 DDR | 120 GB 7.2k WD
        WinXP Pro | MediaEngine | 12.1 VGA TFT Touch|Creative CIMR-100
        350w Vector | 320w mATX PS | Hellroaring BIC95150 | ButterflySDC
