media engine not working on xp pro
  • media engine not working on xp pro
    does any one have a solution for running media engine on xp pro.. the problem een with the latest updates is that the ME shuts down after 3 sec..
    98.8 complete
    95 chevy blazer s10
    must be something isolated to your setup, i run ME on XP pro with no autoshutdown (Crashes) at all. Take a look in the debug.log file and see if theres any helpfull info there as to why its crashing.
    beer replenishment fund
    mp3car live search
      i have two machines and in both don't work ... did it work from the begining or did you do something specail to det it to work...both my machines have xp pro ... and i tried on my brothers he has xp home and i worked fine
      98.8 complete
      95 chevy blazer s10
        I have this problem with WinXP Pro fully patched while running the latest ME2.x. So I just run ME1.77 and I'm good to go
        1993 BMW 325is - 15.2sec
          I don't have the same problem, win xp pro, fully patched...
            Wierd problems like this SUCK to debug
            + My 2 cents
            [H]4 Life
            I'm a lesbian too.
            I am for hire!
              i was told to
              Delete settings.ini
              Delete kb.ini
              Delete keys.ini
              Delete tags.mdb
              Delete me_audio.m3u
              Delete me_video.m3u
              Delete debug.log
              Next, run the Unregger.exe file (this releases the activeX exes from the registry)...then run the app again
              i haven't try these yet but i'm going to .. for sure
              by the way where can i get ME 1.77
              98.8 complete
              95 chevy blazer s10
                it worked on xp from the beginning, ive tested it on about 3 computers at my house and one at work, all running xp pro
                mp3car live search
                  Its working on XP Pro now, I clean installed it again. Going to use XPLite in a few min and see if it works
                    Okay, XP Lite is installed, and ME2 works.. And then it crashes in ~1min or so from startup. Ideas??
                      is not the xp pro or the mediaengine is the mp3 file id tag the makes it crash! I don't know why... i read in winamp.com i think that someone had comeout with something that was able to attach to the id tag and when you run it i'll make winamp crash... so i remember! try this so i can proot it. make a new folder for your media and inside of it a folder for your mp3s .them install the ME and set it to the folder you had just made... rememmber to put in 1 or 2 mp3 in the folder. look at the log file i'll tell you which mp3 are making it crash. now that's the problem on mine pc but i don't know the solution...
                      98.8 complete
                      95 chevy blazer s10
                        I dont know what happened to mine, but it works now
                          well. what did you do to it...
                          98.8 complete
                          95 chevy blazer s10
                            He was running it in his VW. lol J/K
                            Your VW come with the Engine check light option? lol
                            SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
                            GPSing - Digital Speedo
                            Relocating headunit and extending faceplate
                            Button app to Alt-Tab between two programs
                              I reinstalled XP. And no, my light has never come on.. We really don't have that problem as much as people thing! Percentage wise at least..
