IG3 issues with the map/integration
  • IG3 issues with the map/integration
    I have two minor issues with MI and IGuidance 3
    1. It seems that the bottom and top are a little clipped off by the control buttons, I can't see the info that IG3 gives me on the bottom, but I have access to the menu button/mute button and all those goodies. Is there anything I can do for it to scale to fit in the MI window properly?
    2. Whenever I accidentally move the map in IG3, like dragging the screen, it stops refreshing the map. I will still get the directions spoken to me, but the map won't refresh as I am moving until i re-drag. Also, in addition to this, is there anyway to re-center the map if i move it?
    thank you
    when you move the map the red mute button is replaced by a red X, this will then recenter the map to your current location
    you can resize the size of the window by adjusting it in the options for mobile impact
      you are a life saver, thank you
        Hey DJ, your hired!!!, im gonna send all my tech support your way from now on, Heh heh, thanks for helping out.
        Mobile Impact
        Highly innovative car computer multimedia/entertainment system software.
        http://mobileimpact.biz.tm
          Anything to keep the project going, life gets in the way sometimes so I know how it is being super busy. It actually spurned me to resize the scren myself as I'd just been too lazy to do it in the past.
