Problem starting FreeDrive with Mobile Impact
  • Problem starting FreeDrive with Mobile Impact
    When i start freedrive with Mobile Impact, I get this message "Loading Alternative GPS Program" and then nothing happens.
    Anybody knows what is wrong?
    //Kim
    Volvo 850 Car PC Project:
    VIA Epia M10000, 8" Touchscreen, GPS and more.
    //Kim
    The program is specifically looking for freedrive.exe in the following path.
    C:\program files\freedrive\ This cannot be changed as it is hard coded.
    The message states that its loading alternative gps program tells me that you set up free drive in the external apps module. The program has internal code that will detect if Freedrive is installed automatically. So go into your config.ini file and remove the GPSPATH and GPSCLASS entries, then make sure that Freedrive is installed in the path that I described. Let me know if this fixes it, if not we can try a few other things.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
