Problem embedding iguidance
  • Problem embedding iguidance
    Hello everyone,
    I have had Mobile Impact with iGuidance working for several months now, however, recently, iGuidance has been loading and not taking up the entire screen like it used to. Now, it doesn't click the warning dialogue at the start or set the screen size to work with MI. Just curious, I'm sure it is something that I did, but I have no idea what it was. I went into the .ini file and changed the gps screen dimensions to the recommended settings, they deveated a bit, but that did nothing. Any help would be great...
    Thanks,
    Dave
    Edit: BTW it is running at 800x600 on a 8" Lilliput
    Biostar IDeq Mini-ITX - AMD Semperon 2300/256MB RAM/DVD-RAM/80G HD/TV/FM/XM with an 8" Liliput TS iGuidance GPS embedded in MobileImpact.
    Originally posted by xteror
    Hello everyone,
    Thanks,
    Dave
    If iGuidance is running twice that will cause this problem. Another thing that might be happening is something has gotten messed up with either Mobile Impact or with iGuidance. The way to fix it here is uninstall both programs, and make sure that you delete the directories afterwards to make sure everything is gone, then reinstall them. Hope this helps.
    Mobile Impact
    Highly innovative car computer multimedia/entertainment system software.
    http://mobileimpact.biz.tm
      Thanks for the reply. There is definitely on one instance of iGuidance running. I was thinking about reinstalling iguidance since I upgraded from scratch from mi206b to mi207b with no change. The only problem is a buddy of mine has this disc for iguidance so I have to get that back from him first. When I do that I will definitely try the reinstall. Thanks
      Does anyone else have a more technical idea as to the problem so that if it happens again in the future I don't have to reinstall?
        My next version release has much more solid code to embed iGuidance, it will also have touch friendly front end menus as well.
        Mobile Impact
